v15 - 404 error / 486 Busy here
Discussion in 'Ideas' started by Philip Darnell, Jan 26, 2017.
v15 - 404 error / 486 Busy here 5 5 3votes
5/5, 3 votes
  1. Philip Darnell
    Philip Darnell New Member
    Jan 26, 2017
    158
    10
    Whenever I make a call to an incorrect number my call just fails and cuts off, when looking on the management console I see the following error:
    SIP Server/Call Manager ID: 12294
    Call or Registration to 0********3@(Ln.10000@VoiceFlex) has failed. **.**.***.** replied: 404 Not Found; from IP:**.**.***.**:5060
    I think it would be a good idea for an audio message to be playing saying something along the lines of 'you've dialed an incorrect number'
    Also when dialing a number that is busy, we just receive 486 Busy here and again cuts off, making my customers think its the phone system that isn't working, this would be useful to play an audio message 'Sorry the number you have dialled is busy'
