V15.5 Beta
Discussion in '3CX Phone System - General' started by neville, May 10, 2017.
  1. neville
    neville New Member
    Apr 23, 2012
    226
    42
    I installed a system on an OVH server on Friday. I used the following per the docs:
    wget -O- http://downloads.3cx.com/downloads/3cxpbx/public.key | apt-key add -
    echo "deb http://downloads.3cx.com/downloads/3cxpbx/ /" | tee /etc/apt/sources.list.d/3cxpbx.list
    apt-get update
    apt-get install 3cxpbx
    I got the beta version instead of the latest production version.
    How do I get V15 update 5 instead of the V15.5 beta as I do not run anything other then production versions for my client.
    I assume I can do a backup, uninstall and reinstall the correct version and then import the backup.
