v15.5 @ Debian: Exchange Sync results in http 413 error
Discussion in '3CX Phone System - General' started by Lev, Jul 20, 2017.
  1. Lev
    Lev New Member
    Sep 19, 2015
    122
    18
    - v.15.5 @ Debian
    - Exchange 2013 (on premise)
    - only "standard authentication" is enabled on the EWS site
    - client ssl certificates are set to be ignored
    The logs will give me this error:
    2017/07/20 14:02:39.721|810|0045|Info|Synchronization of GAL started...
    2017/07/20 14:02:39.721|810|0045|Info|Synchronization of public folders started...
    2017/07/20 14:02:39.722|810|0045|Info|Synchronization of Public Folder Kontakte\NMS Kunden started...
    2017/07/20 14:02:40.021|810|0033|Erro|Error while checking contacts from Public Folder Kontakte\NMS Kunden
    2017/07/20 14:02:40.026|810|0033|Excpt|Microsoft.Exchange.WebServices.Data.ServiceRequestException: The request failed. The remote server returned an error: (413) Request Entity Too Large. ---> System.Net.WebException: The remote server returned an error: (413) Request Entity Too Large.
    at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
    at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)
    --- End of stack trace from previous location where exception was thrown ---
    I tried adjusting the uploadreadaheadsize to different values (even tried the hightes possible state), but i keep getting the same error.
    Any ideas?
  2. Lev
    Lev New Member
    Sep 19, 2015
    122
    18
    Last night, i did a last attempt on changing the uploadreadaheadsize. This time the value was set to 1048576
    Right after the change, it would still not sync.
    This morning i figured out, that 3CX had actually synced again.
    I cannot tell, what the reason is. Maybe it was just some kind of exchange or IIS cache thing?
