V15.5 is Near. Get your Hands on the Release Candidate
Discussion in '3CX Phone System - General' started by Bianca, May 24, 2017.
  1. Bianca
    3CX Support
    Dec 9, 2015
    49
    10
    #1 Bianca, May 24, 2017
  2. jakub@bodleid.is
    Jan 25, 2016
    6
    change log says:
    "Added visual feedback when uploading VAD projects."
    Is VAD ready? Can we start using it now for v15.5 RC?
  3. clarityscg
    Oct 16, 2008
    17
    We updated a Debian system to Ver 15.5 RC this morning to the RC - we are using it in production at one of our smaller offices. The update did require using "get app" command via SSH. This went very smooth!
    Where is the VAD located, I cannot find it.
  4. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    We are going to release a build this week. Wait for it.
    edossantos likes this.
  5. biba
    Mar 15, 2011
    8
    A known isssue for Linux is that multiple calls are not received by agents in queue or in ring groups has this been fixed? If not please fix it before final release.
  6. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    170
    59
    Biba, have you set the ALLOWUSEBUSYOPTFORGROUP parameter?
  7. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    Correct that is the parameter. Allowbusyoptforgroups
  8. dan_tx
    Nov 3, 2016
    84
    22
    I'm on v 15.0 and currently just see on the update page an update available to the Beta, not the RC. Is it required to update to the Beta to be able to update to the RC or can you go directly to it via the update page within the console? I'm aware I could download RC, backup settings, uninstall, reinstall, restore settings, but prefer the one click update provided by the console.
    Shown on the console update page______
    Beta New BETA Update Available Out Of Date 15.0.62928.5 15.5.715.6 New BETA Update Available Version 15.5 Build 715
    Latest version (RC) is 15.5.1136.6
  9. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,962
    180
    Yes. You must upgrade in order as you do with LIVE PRODUCTION Service Packs.
  10. craigreilly
    Feb 1, 2012
    2,962
    180
    Oh the update is so nice... I just wish Grandstream would be more supported. But they say they will not be doing a Firmware with uaCSTA.
    I can not get approval to buy new supported phones with the hopes that someone will buy my Grandstreams.
  11. davi807
    Jun 29, 2012
    6
    Hi Nicky,
    Great to see the 15.5 RC, however I note that there's still an issue when trying to select a specific handset or softphone where you have multiple handsets of the same model and firmware on the same extension. The same applies for multiple softphones on the same extension.
    As an example, I work from (2) different physical locations.
    At each location I have a T46G and a PC with the 3cx softphone installed.
    As shown in the below picture, in the webclient there's no way of deciphering the locations and similarly, there's no ability to select just one or the other - you can only ever select BOTH handsets.
    This is problematic as I only want to use (1) of them at a time. The same applies to the softphone selection.
    Without the webclient being able to make the distinction between multiple identical devices and the further ability to select just one device, this feature is of little use to many of our users.
    Thanks, David
    PS - I have already factory reset these devices as previously suggested.
    craigreilly likes this.
  12. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    Very true - we will discuss this internally and see what we can do.
  13. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    When can be expected '302 diversion header' forwarding feature to be available again ?
    Many corporate customers asking for it and lack of it prevents upgrading to V15 / 15.5.
  14. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    The RC for now is declared as a beta update (So it is not auto installed). It is classified as a beta but it is a release candidate as the description says.
    You can update via the management console.
  15. Schrodz
    Apr 21, 2017
    91
    9
    I dont have the option to update via the management console.... You say the VAD is this week?
  16. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    What version do you have on the dashboard? You should have a new available update. beta update.
    Vad yes this week or early next week. Actually it's not vad anymore but "3CX Call Flow Designer". Bear with us a little longer.
  17. Schrodz
    Apr 21, 2017
    91
    9
    Hopefully you do it this week as that is all we are waiting for until we purchase a 64sc licence....Sorted the update, was just having a moment!
  18. mcbsys
    mcbsys New Member
    Oct 8, 2008
    171
    14
    I accidentally downloaded the beta 3CX Windows client in a production environment. I do not want this installed on workstations. I've deleted C:\ProgramData\3CX\Instance1\Data\Http\Interface\MyPhone\3CXPhoneWindowsUpdate.zip on the server, but the dashboard does not update to show the Windows client available again. How do I de-authorize a download?
    Maybe we need a checkbox on the Updates screen or a 0/1 switch in Parameters "Show Beta software", unchecked by default. Easy beta testing is great but it's too easy to see those red numbers bubbles in the header and think you need to fix that notification...
    #18 mcbsys, May 26, 2017
  19. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    The update of the client is final. It will not change.
    What is the problem? Why you want to revert the clients?
  20. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    Note about this parameter
    ALLOWUSEBUSYOPTFORGROUP works on Windows and Linux. Parameter is an experimental parameter which will cause issues in reporting
    Applies to Ring Groups only - go to the parameter table and set it to 1
    Set extension to accept more than 1 call (configured from Extension Properties, Forwarding Rules.
    Enable "Accept calls from Ring Group".
    Restart SIP Server.
