v15.5 MoH playlists not working
Discussion in '3CX Phone System - General' started by WolfgangOne, Jun 14, 2017.
  1. WolfgangOne
    Nov 17, 2016
    25
    9
    I've updated to 15.5 yesterday, and was very eager to use the music on hold playlists. However, they're not working.
    During troubleshooting, I have determined that: If I set the Settings -> Call Parking -> Music on hold file to a specific wav file, as before, then listen to a parked call / call a park with nothing parked in it (thus parking myself), I hear the music. If I set that setting to my MoH playlist, which presently contains a copy of the exact same wav file (for diagnostic purposes), I hear nothing.
    Is there something I'm missing somewhere?
  2. StefanW
    Jun 2, 2009
    1,230
    95
    If you are a windows user this feat as also the hotel module requires a backup uninstall install restore.
  3. WolfgangOne
    Nov 17, 2016
    25
    9
    That's pretty outstandingly inconvenient. I guess I'll be doing that later.
    sjp_crs and Eric Osborn like this.
  4. saqqara16
    Jan 13, 2016
    47
    7
    What options are required when backing up the system ?
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    563
    You can backup using all options. You only need the new installer to so that the service gets created.
  6. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,325
    221
    Thanks for info, done some of our client without any issues
