V15.5 SP2 BUG: Call log
Discussion in '3CX Phone System - General' started by ygonzales, Dec 1, 2017.
  1. ygonzales
    Nov 3, 2016
    12
    If you go to call log you can see a history
    but after update:
    after 00:00 time (start of a new day), call log is empty
    how ever, in dashboard it says: purge 15 call logs
    Even if you try to export 1 week history attachment comes empty
  2. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    79
    Do you have a filter set?
