Solved v15.5 SP3 not showing
Discussion in '3CX Phone System - General' started by FMRS_IT, Mar 7, 2018.
  1. FMRS_IT
    Jan 29, 2018
    10
    I'm currently using v15.5.0 (Pro version). I don't see the SP3 update in the management console. The PBX is installed in a Windows Server 2012 R2 copy. At the server, I can successfully ping download-us.3cx.com.
    The 3CX copy was fresh install at 15.5 with v14 backup.
    Tested different DOWNLOADS_URL values:
    Attached are screenshot of DOWNLOADS_URL setting and the the current Update screen.
  2. eddv123
    eddv123 Active Member
    Aug 15, 2017
    909
    138
    Hi FRMS_IT,
    A couple of questions for you:
    * Are you in valid maintenance.
    * If you restart the services on the 3CX-PBX (out of office hours) does anything appear then.
    As long as you are in maintenance and have a direct internet connection everything should be fine.
  3. FMRS_IT
    Jan 29, 2018
    10
    I think I should have maintenance. Here is what it is in the license page. I will try to restart the PBX after hour and see anything change.
  4. CentrexJ
    CentrexJ Member
    May 5, 2009
    388
    52
    You may already have SP3. On the Dashboard, under information, License what is the full build number? Mine is 15.5.9348.3. The .3 indicates SP3.
    FMRS_IT likes this.
  5. FMRS_IT
    Jan 29, 2018
    10
    Oh you are right. It's showing at dashboard but not the license menu, strange. Thank you!
