V15.5 Update 3 - Call Log Hot Fix
Discussion in '3CX Phone System - General' started by nb, Feb 23, 2018.
  1. nb
    nb Support Team
    Jun 7, 2007
    2,123
    150
    #1 nb, Feb 23, 2018
    Mark@EvoIT, jed, accentlogic and 2 others like this.
  2. AH2
    AH2 New Member
    Mar 14, 2017
    112
  3. loyer
    May 5, 2016
    43
    I updated .... and I see call logs!!! Thanks!!
  4. AH2
    AH2 New Member
    Mar 14, 2017
    112
    Same here, all good so far, will post if anything out of place :) Thanks for the fix.
  5. imerecom
    Dec 2, 2009
    21
    no updates available just a sip trunk how long before they propagate installed version is 15.5.8801.3
  6. Flash99
    Aug 3, 2017
    83
    7
    no updates available too
    I'm on 15.5.8801.3
  7. StefanW
    Jun 2, 2009
    1,215
    87
    hello,
    ensure you are not looking into the beta repository withing the Parameters of the PBX. Also the PBX checks in an 2h cycle if there are updates, so there might be for some a delay until it appears.
    Here the correct update path within the pbx settings -> parameters:
    Param Name: DOWNLOADS_URL
    Value: https://downloads-global.3cx.com/downloads/v155/
  8. imerecom
    Dec 2, 2009
    21
  9. Flash99
    Aug 3, 2017
    83
    7
    I guess I'll wait for 2 hours
  10. network51
    Mar 10, 2014
    6
    8
    Nice job on the fast fix 3cx! Glad we caught that.
  11. StefanW
    Jun 2, 2009
    1,215
    87
    you can remain using -us as this is an alias of -global. We moved to an CDN for software delivery which takes time to populate all the PODs we have worldwide. If you press on the update butten it looks for updates from cache so, some time is needed to get the latest update file.
  12. imerecom
    Dec 2, 2009
    21
    thank it is there now.
    what about those whom did not do sp3 will the sp3 disappear and sp3 hot fix appear it its place?
  13. Brian Buell
    Aug 9, 2017
    30
    Thank you for the update. Please feel to close out trouble ticket - 183452
  14. Colddevil
    Jun 14, 2016
    13
    This had been becoming a real issue when trying to troubleshoot a recent problem. I'm glad to see that this fix is out. Looking forward to applying the update.
  15. Omar Ali
    Nov 17, 2017
    20
    so afraid to install another update, SP3 was a disaster for us. Will wait another week to hear all the comments/concerns with this fix before installing.
  16. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    It's just a patch. Works great.
  17. fahillion
    Apr 30, 2010
    5
    Patched a few systems and it is working properly.
  18. Mark@EvoIT
    Mar 16, 2017
    19
    Also for some check your start-up scripts in case you've rebooted since last updates. I had to update my start-up scripts to ensure I was pointing to the correct update servers in my 3cxpbx.list for repo's. Made changes via ssh to update those repos only to notice on a few I rebooted the start-up scripts reverted them back to the previous depreciated repos.
  19. Paul Hine
    Feb 25, 2018
    Since downloading this patch the management console is stuck in a loop of re-loading/refreshing.
    According to https://www.3cx.com/community/threads/3cx-management-console-stuck-in-loop.49297/ it looks like it could be a failed update.
    Is there any way to manually download/apply the update as I’m now unable to use the management console? I’m trying to avoid having to do a full uninstall/reinstall if possible.
    Any advice would be much appreciated. Thanks
  20. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    @Paul Hine
    Please open an incognito window in chrome and try accessing the management console. Let me know if the issue persists. Also is this a windows or a linux installation?
