V15.5, Update 4 BETA: Voicemail to text transcription, queue ringtones and more…
Discussion in '3CX Phone System - General' started by Bianca, Mar 21, 2018.
  1. nb
    nb Support Team
    Jun 7, 2007
    2,153
    170
    jed, Nick Galea and LeonidasG like this.
  2. tratz
    tratz New Member
    Oct 21, 2015
    111
    16
    We have multiple page groups. Looking at the video can the phones be in multiple page groups? We normally have one building wide and some that are department specific. Will there be a way to add in multiple mulitpage groups as most supported phones can handle at least 4 or 5. Also is the technical reason why the multicast is disabled for SBC is that the SBC uses multicast for PNP of the phones and that they interfere?
    --Tracy
    #2 tratz, Mar 21, 2018
  3. plochu
    Mar 6, 2018
    17
    7
    Voicemail Transcription is great feature but I'm slightly confused now...
    I'm using Google Cloud to host instances (but I can move them to AWS).
    To use Text2Speech in CFD I use AWS Polly (can't use other engine).
    Now to use Voicemail Transcription I will need Microsoft Azure (can't use other engine).
    It starts to look very complicated.
    Why don't use all engines from AWS - Amazon Polly for t2s and Amazon LEX for s2t?
    Regards
    craigreilly likes this.
  4. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    Amazing Update!
    I'm eagerly trying to use the transcription feature. I created the Bing Speech API key and copied it into 3CX as per the documentation. I also waited over 10 minutes because on the Azure site where it shows the keys it says they may not work for up to 10 minutes. When I receive a voicemail to email it looks like it did before but it has a line "Transcription:" but no transcription after. Speech Language set to "English (United States)" and even tried restarting the 3CX services. Also tried "English (Canada)" but switched to US when testing didn't work because I figured that would be more likely to work.
    The phone provisioning options get better and better -- thank you. However, for it to be truly useful for large deployments we need to be able to do multi extension edits and global system defaults would also be awesome. For the small sites it's not too bad to go extension to extension and set the settings. But for large sites it's too much work and prone to human error.
  5. iron
    Apr 28, 2011
    24
    13
    Anyone know if the VM to text API method (not the email part of the method) is HIPAA compliant?
  6. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
  7. poynter.net
    Aug 26, 2009
    34
    Will SIP TLS, SRTP and TLS provisioning be in the final SP4 release?
  8. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
  9. danimal
    Apr 24, 2017
    20
    Why can't standard license users have Voicemail to text? Would be nice...i'd even pay an additional fee. Thanks.
  10. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    $50 a month additional for 8 concurrent users and you get this and more!
  11. ivank
    3CX Support
    Jan 4, 2017
    54
    6
    The speech is sent to Bing Service via Secure WebSocket channel, if that's what bothering you. So is the answer received.
  12. ivank
    3CX Support
    Jan 4, 2017
    54
    6
    Could you please set logs to Verbose, restart 3CX System Service, record a voicemail and send zipped 3cxSystemService.log to me in a PM?
  13. DARSFoG
    Dec 20, 2016
    19
    Question/Suggestion...
    I like how you added the ability to change ring tones for the Queue, Could an option be made to allow you to choose the External and Internal ring tones as well? I know you have the "Configure default ringtone" (at least on the yealink template) but that only effects internal calls and by default, the Ring1 (long standard ring) is set for internal and Ring2 (two short standard rings) are set for External. A lot of my clients like to have them switched.
    EDIT: And to those asking about HIPAA Compliance. According to Microsoft, it should be.
    https://www.microsoft.com/en-us/TrustCenter/Compliance/HIPAA
    #13 DARSFoG, Mar 21, 2018
  14. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,551
    298
    This is possible. Use your keys as you would in Excel to select multiple records, then select EDIT.
  15. craigreilly
    Feb 1, 2012
    3,551
    298
    Agree here. Folks change the ring tones - but then tell me its not working properly. They dont realize it doesn't affect both. (using Grandstream)
  16. craigreilly
    Feb 1, 2012
    3,551
    298
    My voicemails on my iPhone are pretty amusing too and lots of _____ for unknown stuttering and annunciations. Maybe someday they will be perfect. But for the most part, I get the gist of what they are trying to say.
  17. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    Multi extension edits, yes, but not to edit the provisioning options of the supported phones (e.g. date format, time format, ringtone, power led, backlight, paging).
  18. craigreilly
    Feb 1, 2012
    3,551
    298
    Dear 3cx,
    Can you also Allow us to select a Ring Group / Paging Group when provisioning a BLF?
    Keep us the great work.
  19. bbaker73
    bbaker73 New Member
    Nov 27, 2015
    142
    25
    Dashboard, PBX Status, phones is red on my test server. "You are using Unsupported phones or phones with custom templates which may cause issues."
    Connected test phones are all up to date and supported. After some digging, I found I had tested a conference phone with a custom template and never deleted it. I'm thinking maybe have the indicator only relate to connected phones and not extensions, or/also have the informational warning possibly list extensions with the violation so we're not looking for a needle in a haystack.
  20. techclarity
    techclarity New Member
    Nov 14, 2014
    109
    50
    Voicemail transcription is awesome! Been waiting for this feature!
