v15 and Patton FXO partitioning
Discussion in '3CX Phone System - General' started by linking13, Nov 22, 2016.
  1. linking13
    Nov 14, 2008
    44
    I need to create a partitioning of a Gateway Patton 4114 for outbound roule, in particular I need to uso interface 0/0 and 0/1 for a rule, 0/2 for another rule (reserved line for collegue calling) and 0/3 for fax line.
    With the previous versione of 3CX no problem beacuse was created many SIP account as the line present on the Patton and then I was able to applye the old trick for this problem. With v15 I have only one SIP account for the gateway and the trick is no more valid.
    A workaround is to use and old config file and threath the line associated to the single sip account.
    There is a template or a way to do this in a more clean mode?
