v15 backups to UNC path
Discussion in 'Ideas' started by giwm, Feb 9, 2017.
v15 backups to UNC path 5 5 11votes
5/5, 11 votes
  1. giwm
    giwm New Member
    Sep 27, 2016
    236
    41
    Though this feature existed in v14, it apparently now falls under the "3CX Ideas" category as it was removed in v15. The ability to backup to a UNC path makes backup routines incredibly easy without anything special running. This eliminates the need for an FTP server or script reliance to dump those backups off the local drive.
    Lucas Garcia likes this.
  2. giwm
    giwm New Member
    Sep 27, 2016
    236
    41
    I just tested on 15.5 SP1 and this now works again. I'm guessing this was what was meant by the Change Log item:
    Fixed Backup retrieving and saving of backups when location type is FTP or DRIVE.
    Thanks!
  3. Joe W
    Apr 10, 2017
    17
    5
    So you pick "Local Drive" and type in a UNC path? All I see is Local Disk, FTP, Google Drive.
    jj1 likes this.
  4. giwm
    giwm New Member
    Sep 27, 2016
    236
    41
  5. jj1
    jj1
    Feb 23, 2012
    24
    Have just tried this on 15.5 Service Pack 1 and it refuses to accept a UNC path or Mapped Drive as the backup location.
  6. giwm
    giwm New Member
    Sep 27, 2016
    236
    41
    @jj1 If it's not accepting even a mapped drive when Local Disk is selected, then that may be an issue you'd want to contact support about.
    You also may want to ensure it's not a permissions issue (especially with a UNC path). If using a UNC path, you'll want to give the host running 3CX modify permission on the target folder.
