V15, "Call from extension(s)'' field limited to 50 characters
Discussion in '3CX Phone System - General' started by Ben C, Jul 29, 2016.
  1. Ben C
    Oct 14, 2014
    71
    I'm testing V15 and I'm creating same outbounds rules I have on V14. I noticed that all 3 fields under 'Apply this rule to these calls' are limited to 50 characters. These 3 fields don't have this limitation on V14 and the rule I use has 145 characters (including commas).
    I'm using a free 3CX v15 PBX Edition 8SC license key. Is this limitation related to this type of licence? Or is this overlooked?
    Thank you
    Ben C
  2. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    Hi Ben, are you running the latest service pack?
  3. Ben C
    Oct 14, 2014
    71
    Yes, I just installed SP1 today,
    License: PBX 15.0.56772.0
  4. Aram
    Aram Support Team
    May 7, 2012
    154
    30
    Hi Ben,
    I just tested my V15 SP1 and I'm able to put the 200 characters into the "Calls to numbers starting with prefix" and "Calls from extension(s)" fields.
    Only "Calls to Numbers with a length of" have the limitation, but I think you will not dial numbers with the length more then 1000000 characters.
    What browser you are using?
    Please try it on Chrome. Clear the Chrome browser cash and try there.
  5. Ben C
    Oct 14, 2014
    71
    I tried today and it's working !!!
    Last time I tried it was on Friday...
    Yes I'm using chrome (latest version)
    Thank you guys
