v15 Calls Not Recording Automatically
Discussion in '3CX Phone System - General' started by JStellato, Jul 14, 2016.
  1. JStellato
    Dec 17, 2015
    33
    6
    After the upgrade from 14 to 15, no calls are being recorded. Extensions that are set to auto record have been checked, the location verified. I have made sure NTFS Permissions were set to allow full control for all users of the computer. And I've set the quota for triple the space used.
    I had performed the backup and restore procedure, when it restored it changed all the file dates of the existing recordings to when it was restored. Anyone else experiencing this?
  2. JStellato
    Dec 17, 2015
    33
    6
    Ok For anyone else experiencing this, it's because even though I changed the Quota to three times what was in use, the initial in use size was over the 5GB default that was set. Changing the quota and waiting an hour didn't affect it. I manually restarted all the services and it started recording again.
  3. ryan.rosenberg@nobullblinds.com.au
    Dec 14, 2015
    I am having the same issue, I may roll back to V14 as it is quite important for me. I did change the default directory to the same directory as I was running on 14. This shows my old call recordings on 3cx clients but nothing new.
    I have also restarted the services, changed my quota to 20x my current usage and no luck. I looks as if it trying to verify the size of the drive but does not come back with a value. Tried the root and the same drive as the installed directory still no luck.
  4. ryan.rosenberg@nobullblinds.com.au
    Dec 14, 2015
    Just increased my quota to 9TB and calls started recording. (Currently using 66GB).
