V15: Can not search for contacts from briged system
Discussion in 'Windows' started by wtrbhe, Aug 24, 2016.
  1. wtrbhe
    Oct 9, 2015
    22
    we have two 3cx systems that are briged.
    In 3cx Phone for Windows at presence information screen i can see all local and remote extensions and a input-box that says "Enter name or number", thats fine. Starting to search mister Kowalski, who is located on remote system and was showed before, the system founds ... nothing. Why can i see remote extensions but not search for them?
