Solved v15 cant access management console.
Discussion in '3CX Phone System - General' started by Kevin Burns, Jul 12, 2017.
  1. Kevin Burns
    Apr 3, 2017
    43
    Hello, I am running v15.5 on a windows 10 machine. I was using it fine on monday and then I came back to it today and I cannot access it from different browsers or remotely. Services are working fine. I either get a timed out error or a connection refused error. I have tried access the console from the host machine to no avail.
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,626
    248
    Restart the services or the PC? Is there some sort of 3rd party firewall software on there? Is the machine set to DHCP by any chance? There isn't really a question here.
  3. Kevin Burns
    Apr 3, 2017
    43
    Sadly I wont be able to try to restart the pc for a couple of hours because the phones are currently in use. It is using windows defender and the 3cx features are all on the approved app list. It should be set to static. I guess my question is, has anyone had the same problem and know how to access the management console or know a fix to this? Like I said it was working fine on Monday and no one has touched it since I got back to it today. I am not sure how I broke it.
  4. agp
    agp 3CX Team
    Aug 19, 2015
    151
    22
    Have you tried opening the Management Console via the local IP on port 5000? (assuming that you are running on the default ports).
    Is the 3CX PhoneSystem Nginx Server service running?
  5. Kevin Burns
    Apr 3, 2017
    43
  6. Kevin Burns
    Apr 3, 2017
    43
    I am not sure if the nginx server is running. I do not see it in the tasklist
  7. Kevin Burns
    Apr 3, 2017
    43
    I fixed it thank you. Somehow my nginx server was no longer running. If anyone else has this problem press the windows key and open up services. On the list you will see a bunch of 3cx services. Make sure the nginx server and the management console options are both running.
    idlea likes this.
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,460
    541
    Gals the issue is resolved and thank you for sharing your solution
    Kevin Burns likes this.
  9. idlea
    May 6, 2009
    5
    I have not used 3CX for 8 years and now I remember why I binned it last time.
    So what is the answer other than restarting the service every day????????/
    Oh and thank you Kevin
  10. LyonAdmiral
    Aug 10, 2015
    51
    I've had it on Windows 7, with the firewall configured tightly for only what 3CX needs, and I've got months without installing updates or restarting anything.
  11. idlea
    May 6, 2009
    5
    I have an old pc with 7 on it doing nothing I will give it a try.
