v15 & Exchange 2013 Contacts sync failing
Discussion in '3CX Phone System - General' started by Daniel Ormanns, Oct 13, 2017.
  1. Daniel Ormanns
    Oct 13, 2017
    5
    Hi Guys,
    i am new to 3cx and I think i got the most things done for my company.
    But the Sync of contacts is a mystery to me.
    I created the entries for Exchange in the Contacts Section (Version is Exchange 2013 with SP1)
    And my private Contacts are synced, but I get Errors syncing publicFolders.
    Out of the logfile:
    2017/10/13 12:22:56.710|2464|0072|Excpt|System.Exception: Top Level Folder not found: BPG
    bei CompanyDirectoryService.Clients.PublicFolderExtensions.<GetTopLevelFolder>d__2.MoveNext()
    --- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---
    bei System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
    bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
    bei CompanyDirectoryService.Clients.PublicFolderExtensions.<GetPublicFolderByPath>d__1.MoveNext()
    bei CompanyDirectoryService.Clients.PublicFolderExtensions.<GetContactsFromPublicFolder>d__4.MoveNext()
    bei CompanyDirectoryService.SchedulerJob.<SynchronizePublicFolderContacts>d__15.MoveNext()
    I tried different writings of the Foldername in the Configuration and it is always the same Error.
    How can I solve this?
    Thank you!
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Daniel,
    Ensure that the 'slash' is a FORWARD slash not a BACK slash.
    Also, no slash should be input infront of the public folder path.
    #2 GiannosC_3CX, Oct 13, 2017
  3. Daniel Ormanns
    Oct 13, 2017
    5
    Hi Giannos,
    thank you for the quick reply.
    I just changed this in my config, but the error persists.
    Log entries:
    2017/10/13 13:29:42.382|2464|0072|Erro|Error while checking contacts from Public Folder BPG\KontakteKR
    2017/10/13 13:29:42.382|2464|0072|Excpt|System.Exception: Top Level Folder not found: BPG\KontakteKR
  4. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Daniel,
    Please try with a FORWARD slash ( / ) not a BACK slash.
  5. Daniel Ormanns
    Oct 13, 2017
    5
    Just the Same error with the other slash
  6. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Daniel,
    Can you attach a screenshot of the error and a screenshot of the settings from the management console?
  7. Daniel Ormanns
    Oct 13, 2017
    5
    Hi Giannos,
    the error only shows up in the logfile with the lines above.
    Here are the 2 Config Pages.
  8. StefanW
    Jun 2, 2009
    1,222
    93
    the image still shows a wrong config, wich will never work.
    https://www.3cx.com/docs/manual/phonebook-directory/
    1. To have the company phonebook populated with contacts from a public folder, enter the path to the public folder for example: Company/Contacts.
    If after entering the URL correct this still remains: Top Level Folder not found: BPG\KontakteKR (or Correct then Top Level Folder not found: BPG/KontakteKR) then the folder is not called like this. May add an image of the Public Folder Tree
  9. Daniel Ormanns
    Oct 13, 2017
    5
    Hi Stefan,
    thank you for your reply, I just changed the config, but the Error is still the same.
    2017/10/16 08:50:58.273|2296|0063|Erro|Error while checking contacts from Public Folder BPG/KontakteKR
    2017/10/16 08:50:58.274|2296|0063|Excpt|System.Exception: Top Level Folder not found: BPG
    I made two screenshots of the config, maybe this helps.
  10. shenwei
    Jun 17, 2016
    40
    5
    No updated? We met this problem too. Personal contacts could be synced. But public folder sync failed.
