V15 gets corrupted after accessing 3cx Management Console
Discussion in '3CX Phone System - General' started by sfchampeau, Oct 30, 2016.
  1. sfchampeau
    Oct 30, 2016
    8
    This scenario has happened twice in a week to me when I try and access the "Welcome to the 3cx Management Console".
    In the dialog box it indicates to enter user name or extension number / password. So, experimenting I enter my extension and passcode from my user account. Failed to login "that ok", but now I'm unable to access via my admin login I reboot 3cx and webpage shows Bad Gateway 502 I try and login, but get a server error.
    I have 3cxV15 installed as a guest operating to vmwork station 12.1 with 1gb memory and 20gb space.
    Thanks,
  2. agp
    agp 3CX Team
    Aug 19, 2015
    134
    19
    Hi sfchampeau,
    Just to test, can you try logging in from another computer?
  3. sfchampeau
    Oct 30, 2016
    8
    Yes, I forgot to mention this was the first thing I did was to try on another computer was well as another browser.
    Opera, Firefox, and Chrome.
    Regards,
    Steve
  4. sfchampeau
    Oct 30, 2016
    8
    Also, want to clarify that this is version debian-8.6.0-amd64-netinst-3cx.iso.
  5. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Could you please confirm that 3CX Management Console service is running?
    I see you are a linux user, so type this pls
    service 3CXPhoneSystemMC01 status
    or
    top -u phonesystem
    Confirm that Management Console is running.
  6. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    Can you also post specs of machine?
    Whoever has this problem, post specs CPU Memory and type of disk
  7. sfchampeau
    Oct 30, 2016
    8
    Nickybrg thanks for the reply.
    Yes, the service is running:
    ● 3CXPhoneSystemMC01.service - 3CX PhoneSystem 01 Management Console
    Loaded: loaded (/lib/systemd/system/3CXPhoneSystemMC01.service; enabled)
    Active: active (running) since Wed 2016-11-02 21:59:22 PDT; 3min 56s ago
    Main PID: 569 (ManagementConso)
    CGroup: /system.slice/3CXPhoneSystemMC01.service
    └─569 /usr/lib/3cxpbx/ManagementConsoleJS -p /var/lib/3cxpbx/Instance1/Data/Http/webroot
    System is a quad core with 4 gb of memory, 250 SSD hard drive and is running 3xzV15 Debian as a guest operating system on VMworkstation 12.1 with 1 core, 1 gb, and 20 gb of space.
    Now here the interesting thing I just reload the old virtual machine that was giving me troubles, but I renamed the virtual machine from 3cx beta to 3cx beta1 because I'm currently working with a clean copy for testing also note the IP Address changed. The bad copy is now working and I'm able to access via the web console.
    So, I followed the same steps to break it.
    I entered an extension 200 and passcode it failed to login. I then tried to login with my Admin login and I received Server Error. I then cleared my browser chrome as well as I tried Opera to login via my Administrator and I received Server error as well as I stopped virtual machine and restart vmworkstation it still failed to login as Administrator.
    Here is status
    Active: active (running) since Wed 2016-11-02 21:59:22 PDT; 18min ago
    Nov 02 21:59:21 kimbatel sudo[707]: phonesystem : TTY=unknown ; PWD=/var/lib/3cxpbx ; USER=root ; COMMAND=/usr/bin/apt-get update -o Dir::Etc::sourcelist=sources.list.d/3cxpbx.l...ist-Cleanup=0
    Nov 02 21:59:21 kimbatel sudo[707]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Nov 02 21:59:22 kimbatel systemd[1]: Started 3CX PhoneSystem 01 Management Console.
    Nov 02 21:59:24 kimbatel sudo[707]: pam_unix(sudo:session): session closed for user root
    Nov 02 22:00:35 kimbatel sudo[785]: phonesystem : TTY=unknown ; PWD=/var/lib/3cxpbx ; USER=root ; COMMAND=/usr/bin/apt-get update -o Dir::Etc::sourcelist=sources.list.d/3cxpbx.l...ist-Cleanup=0
    Nov 02 22:00:35 kimbatel sudo[785]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Nov 02 22:10:59 kimbatel sudo[950]: phonesystem : TTY=unknown ; PWD=/var/lib/3cxpbx ; USER=root ; COMMAND=/usr/bin/apt-get update -o Dir::Etc::sourcelist=sources.list.d/3cxpbx.l...ist-Cleanup=0
    Nov 02 22:10:59 kimbatel sudo[950]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Nov 02 22:12:02 kimbatel sudo[1008]: phonesystem : TTY=unknown ; PWD=/var/lib/3cxpbx ; USER=root ; COMMAND=/usr/bin/apt-get update -o Dir::Etc::sourcelist=sources.list.d/3cxpbx....ist-Cleanup=0
    Nov 02 22:12:02 kimbatel sudo[1008]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Hint: Some lines were ellipsized, use -l to show in full.
  8. sfchampeau
    Oct 30, 2016
    8
    More info I moved the virtual machine 3cxV15 Debian (running VWworkstation 12.1) to another PC started it up and I was able to login Admin via the webconsole.
