V15 Install [solved]
Discussion in '3CX Phone System - General' started by sunkiddance, Jul 12, 2016.
  1. sunkiddance
    Jul 12, 2016
    22
    OK - I backed up my V14 and then un-installed it
    Downloaded the V15 Free Version
    When I try and run the install, I get a message that certain pre-requisites are missing and it then proceeds to install .NET Framework V4.6.
    The problem is that it then just sits there saying it is installing but nothing actually happens. After 30 minutes or so I cancelled the install.
    Tried again after re-booting the server, same result. Tried right-clicking the file and choosing "Run as administrator" - same result.
    Server is running Windows 2008 R2 64-bit
    Help !!
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,968
    181
  3. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Re: V15 Install
    Look ideally we post log of installer, but if problem still persist send me a pm so we can access machine and see this live.
  4. Pojidaev
    Nov 28, 2014
    Re: V15 Install
    Download and install full versions of .NET Framework and C++ Runtime , reboot machine and start 3CX setup. Everything will be fine.
  5. sunkiddance
    Jul 12, 2016
    22
    The server already on SP1.
    Ran the .net cleanup tool. Rebooted server
    Problem the same - even with the stand-alone installer.
    Tried removing .net 4.5.1 , re-boot, cleanup, re-install - same result
    I am now unable to install any version of .net - 4. full install, 4.5.2, 4.6.1 - all start running and just "hang" doing nothing
    I eventually installed it all onto a virtual server running on the original server and that has worked - i.e. 3CX v15 is up and running - it will stay there until I can resolve the issues of installing .net 4.x
    (Incidentally, today I ran other Windows updates on the server without any problems)
    So - issue not actually resolved but at least I have the system working again.
