v15 Outbound Rules - CLI & Import / Export
Discussion in 'Ideas' started by ucs1, Jul 6, 2016.
v15 Outbound Rules - CLI & Import / Export 5 5 4votes
5/5, 4 votes
  1. ucs1
    Jun 21, 2013
    42
    If we could add the ability to override the outbound callerID set on the trunk level from within the OUTBOUND Rule, this would prevent
    A: paying for another trunk
    B: 6 more rules (see below)
    Could we please have import / export functionality added for outbound rules I know there has been some discussion around this but here is an example.
    With our larger hosted customers, they can have 15-20 sites.
    Each site has its own trunk.
    Each trunk needs its own rules for specific types of calling
    Local, National, Mobile, International, Tollfree, Pay Services
    So at best I have 15x6 = 90 rules and then a rule for emergency services for each site.
    3CXDude likes this.
  2. loyer
    May 5, 2016
    43
    +1 to this idea... I would also like to be able to export/import outbound rules. Even if it was a copy/paste of a xml string with all the values... what would be great.
  3. Aytek Aydogan
    Jul 2, 2017
    5
