v15 REPORT_URL
Discussion in '3CX Phone System - General' started by benratty, Aug 15, 2016.
  1. benratty
    May 23, 2011
    74
    I am having a problem with reports from version 15, the link in the email has local IP of the PBX so when users at remote site try to download the report from the emailed link it does not work.
    I have had a look at the parameters and cannot see where the URL for %%REPORT_URL%% in the email template is set. Which URL needs to be changed to make this work?
    All the links in the parameters are set to the internal IP of the PBX, when It set it up it was with a 3cx.co.uk domain.
  2. teldotnet
    May 22, 2009
    73
    did you find an answer to this as we are having same issue
    thanks
    Brian
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,304
    448
    An external link to download reports will be added to SP2. For now the link is only internal
  4. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    That's funny because all my reports use the external link, which I don't want.
  5. nb
    nb Support Team
    Jun 7, 2007
    2,129
    152
    In sp2 you will have the internal and the external in the email.
  6. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    I've got SP2 and there is only one link - for the external url.
  7. nb
    nb Support Team
    Jun 7, 2007
    2,129
    152
    clear cache..
  8. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    It has been.
  9. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Go to Email Templates, edit your custom Reports Template and compare with the one I have below,
    Code:
    <html>
    <head>
    <meta charset="utf-8">
    <style>
    	body{
    		font-family: Arial, Helvetica, sans-serif;
    		margin: 0 auto;
    		width: 662px;
    		font-size:14px;
    </style>
    <title>Call Reports Email</title>
    </head>
    <body>
    <div style="text-align:center">
    <table style="margin:0 auto;width:662px;max-width:662px; height:auto;min-height:200px;text-align:left;">
      <tbody>
        <tr>
          <td><img src="http://www.3cx.com/Mailers/2015/images/3cxPhonesystem-Image1.png" alt="3CX Call Reports Notification"/></td>
        </tr>
        <tr>
    	<tr>
    		<td style="border:1px solid #c3c3cb; padding: 2px;">
    			<p style="color: #404041; ">
    			<strong>Subject:</strong> &nbsp; 3CX Phone System - %%REPORT_NAME%%
    			</p>
    		</td>
    	</tr>
         <td style="border:1px solid #c3c3cb; padding: 10px;">
    		<div id="header" style="width:100%; position:relative; height:auto;" >
    				Your call report - %%REPORT_NAME%% is ready for download.<br>
    				Click the download button below.<br><br>
    					<a href="%%REPORT_URL1%%" target="_blank"><img src="http://www.3cx.com/wp-content/uploads/2015/05/btn_download-blue.jpg" style="display:block;margin:0 auto;"/></a>
    		</p>
    				Report can also be downloaded from <a href="%%REPORT_URL2%%" target="_blank"> here </a>.
    		</p>
    			%%REPORT_LIMIT_REACHED_START%%
                              <br>
    			 <p style="color: red; font-size:12; ">
    			* Report not generated in full because query contains too many records.
    			</p>
    			%%REPORT_LIMIT_REACHED_END%%
    		</div>
          </td>
        </tr>
       <tr style="height:15px"><td></td></tr>
        <tr style="height:100px">
          <td style="background-color: #333333; border-bottom: 10px solid #0197d6; margin-top: 15px; ">
    		  <table style="width:100%"><tr><td style="width:70%"><span style="font-size: 12px; padding: 30px 6px; text-align: justify; color:#e7e7f0;">Sent by 3CX Phone System</span></td>
    		  <td style="width:30%;text-align:right;padding-top:5px;padding-right:38px;"><img src="http://www.3cx.com/Mailers/2015/images/logoBottom.png" alt="3CX"/>
    		  </td></tr></table>
          </td>
        </tr>
      </tbody>
    </table>
    </div>
    </body>
    </html>
    Update yours important part is the following,
    Code:
    Or you can go via custom param find default one and compare with yours.
  10. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    This fixed it. Turns out it was only one location with a messed up template.
