v15: Secure SIP Guide
Discussion in '3CX Phone System - General' started by jens.hartmann, Nov 29, 2016.
  1. jens.hartmann
    Nov 29, 2016
    8
    Where can we find a guide for Secure SIP? Which certificates are supported or can we generate a private one? We saw that 3CX provides custom Snom firmware with Let's encrypt support? How can we use Let's encrypt for secure SIP? Secure SIP should be the default setting..
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Google much?..
    You can generate whatever you want.. but if you want your endpoints to trust yours, implement PKI. You could pull the cert/key pair from the Let's Encrypt section and use it I suppose, though you'd have to copypasta every 90 days.
    Unless you know what you are doing with TLS, Secure SIP is not for you..
  3. jens.hartmann
    Nov 29, 2016
    8
    I know how to handle PKI Infrastructure but secure sip makes less sense when the Root CA's are not trusted at the device level and I wanted to know why 3CX provides a Let's Encrypt firmware for the hardware phones.
