V15 shows non-installed components as needing update
Discussion in '3CX Phone System - General' started by positron, Aug 3, 2016.
  1. positron
    Jan 14, 2013
    76
    11
    In V15, an "Update" option was added at the top of the web portal with a number indicating the number of updates needed to be installed. However, this number includes components which are not installed or needed, such as other promptset languages which will never be used, templates for phones which are not used, CRM integrations which are not used, etc.
    It would seem to make more sense that the number of updates displayed on the menu line should only be for installed components which are in "out of date" status, rather than any available module which is not installed. It is not practical to have to install every language and every CRM integration just to make the update number go away, and then have to be prompted in the future to update unneeded languages and CRM integrations just because they were installed to satisfy the update message.
  2. Sopock
    Sopock Member
    Jul 11, 2012
    444
    20
