v15 sp1 Web management login timeout
Discussion in '3CX Phone System - General' started by 3CXusername, Sep 27, 2016.
  1. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    Using Chrome (no stored credentials/autosign), login never times out. Logout button required. I looked through parameters but could not locate any timeout value.
    Anyone have any ideas?
    thanks.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,404
    281
    Logout button exists on the top right of the management console. Credentials might not be stored but there is a cookie for the session to expire. Use of the logout button might be required you are accessing the management console from an unsecured location
  3. 3CXusername
    Jul 31, 2014
    183
    16
    Thanks for reply.
    v14 - it timed out and did NOT require manual logout.
    v15 - doesn't timeout and requires manual logout.
    Just me or something with my installation or bug??
    thanks.
