Solved v15 SP3 won't install - all services stop
Discussion in '3CX Phone System - General' started by computer150, Mar 19, 2017.
  1. computer150
    Jun 23, 2015
    8
    Hi folks,
    We have an instance that shows SP3 15.0.59950.0 is available but when we click "download selected", we get a warning about shutting down, get redirected back to the logon screen - and then nothing.
    No email received, all 3CX services appear to have stopped on the server - and they stay that way. After waiting over 30 minutes (with the phone system down) I resorted to rebooting the server.
    Upon reboot I get an email to say a service pack has been successfully applied - but it hasn't. I retried this process today (Sunday) with the same result.
    Any suggestions for logs to examine - or perhaps I should backup config and uninstall/reinstall? All suggestions are welcome.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,554
    300
    what browser are you using?
  3. computer150
    Jun 23, 2015
    8
    Chrome 56.0.2924.87
    I think the browser-side behavior is okay through - more that the upgrade obviously starts (all services get shut down), but never completes.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    Hello @computer150
    What version of PBX are you currently on? Can you let us know what is displayed next to the license tab on the dashboard?
  5. computer150
    Jun 23, 2015
    8
    Activated Standard 15.0.59381.0
    Thanks for your help.
  6. YiannisH_3CX
    May 10, 2016
    7,358
    535
    Thank you for the update,
    While the update is running and the services are stopping is there any service stuck on stopping and cannot stop?
    also is the machine (assuming this is a windows machine) up to date with windows updates?
  7. computer150
    Jun 23, 2015
    8
    I'll need to wait for an opportunity when I can try the upgrade again to check the services. Yes, this is on Windows Server 2012 R2. It was patched up to last months Windows updates. I have installed the latest couple of Windows updates since my last attempted 3CX upgrade (KB4012216 - March, 2017 Security Monthly Quality Rollup, and KB890830 Malicious Software Removal tool - March 2017)
  8. computer150
    Jun 23, 2015
    8
    I'm just trying again now. Within about 30 seconds of starting the update and the console logging me out, the services started to shut down. All of the "3CX..." services were stopped within about 15 seconds after that.
    From what I can see from task manager, there doesn't seem to be any process activity (server is dedicated to 3CX).
    Will give it about 15 minutes (or until someone calls to complain) and then restart the server if no sign of progress...
  9. computer150
    Jun 23, 2015
    8
    Not sure if any of these will give a clue:
    Last entries in CloudServiceWatcher.log:
    2017/03/21 21:55:18.247|0004|Info(03)| Event for SP update is set. Starting SP update...
    2017/03/21 21:55:18.302|0004|Info(03)| Starting Updater1 with param https://downloads.3cx.com/downloads/v150/sp150/PatchX4_64.zip
    2017/03/21 21:55:52.749|0003|Info(03)| Service Watcher finishing
    In a backup folder 3CXMediaServer...log
    21:55:52.747|00000540| Info|Service.cpp(193): 9:Stop event has been set
    21:55:52.747|00000548| Info|Service.cpp(767): 9:Stopping service tasks...
    21:55:53.248|00000598|Trace|FileCache.cpp(84): 7:FileCache is exiting
    21:55:53.759|00000548|Trace|MediaServer.cpp(1986): 9:Exiting core tasks
    21:55:54.415|00000c8c| Info|Service.cpp(536): 9:Disconnected from CRASPBX:5482/CallManager at 127.0.0.1:5482
    21:55:54.540|00000548|Trace|MediaServer.cpp(2029): 9:Core tasks are stopped
    21:55:54.540|00000548| Info|Service.cpp(775): 9:All service tasks are stopped
    In 3CXManagmentConsole.log:
    2017/03/21 21:54:57.375|2784|0016|Err|EventConnector.EventRoutePoint has not a connection to 'ConfigurationManagementModel.Events.EventTransformer+PipelineTransformer'
    2017/03/21 21:54:57.377|2784|0029|Err|EventConnector.EventRoutePoint has not a connection to 'ConfigurationManagementModel.Events.EventTransformer+PipelineTransformer'
    2017/03/21 21:55:04.508|2784|0072|Err|CTI:
    System.Xml.XmlException: The 'supportedmodels' start tag on line 269 position 3 does not match the end tag of 'profile'. Line 330, position 5.
    at System.Xml.XmlTextReaderImpl.Throw(Exception e)
    at System.Xml.XmlTextReaderImpl.ThrowTagMismatch(NodeData startTag)
    at System.Xml.XmlTextReaderImpl.ParseEndElement()
    at System.Xml.XmlTextReaderImpl.ParseElementContent()
    at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace)
    at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc)
    at System.Xml.XmlDocument.Load(XmlReader reader)
    at System.Xml.XmlDocument.Load(Stream inStream)
    at ManagementConsoleJS.CheckItem.ReadLocalVersion(String baseDir, String category)
    at ManagementConsoleJS.UpdateService.<CheckAsync>d__25.MoveNext()
    2017/03/21 21:55:18.207|2784|0066|Err|EventConnector.EventRoutePoint has not a connection to 'ConfigurationManagementModel.Events.EventTransformer+PipelineTransformer'
    Any idea what file the last error is referring too? Related?
  10. computer150
    Jun 23, 2015
    8
    No progress and down too long so had to reboot.
    Got the standard "Your 3CX Phone System has been successfully updated!" and "A new update is available for 3CX Phone System." emails but no upgrade has actually happened.
  11. YiannisH_3CX
    May 10, 2016
    7,358
    535
    For close this topic, the issue was due to some Grandstream custom templates inside the PBX folder.
    Once those were removed the update proceeded normally.
  12. computer150
    Jun 23, 2015
    8
    Just a small addendum...
    If anyone needs to find the Updater logs to get clues for resolving these kind of issues, they are located in C:\Program Files\3CX Phone System\Bin and called Updater1.log and Updater2.log.
