v15 SP4 Linux - Activity log empty?
Discussion in '3CX Phone System - General' started by 604, Dec 17, 2016.
    604
    Aug 1, 2016
    12
    I'm running a hosted test server in a Hyper-V VM. Has anyone experienced this issue where after a while (maybe a day or two), the activity log is empty?
    Rebooting does bring the log back but I can't see any activity from before then.
  2. George_3cx
    George_3cx Guest
    Dear 604,
    - In the activity log section --> settings has a checkbox to specify how many days to keep the log files as you can see from the below screenshot:
    - Additionally, when the pbx is restarted all the logging is deleted. This is the expected behavior by design.
  3. 604
    604
    Aug 1, 2016
    12
    I did see that option. I perceived that to mean "Continually keep the last 1 day of logs", not "Record 1 day of logs from boot time, then delete it and stop logging"
    If I uncheck this option, will it keep all logs from last boot until next boot?
  4. noord
    Nov 25, 2015
    32
    I am experiencing exactly the same issue on the same version (Linux SP4). After about a day the logging is deleted and no further actions are logged.
    I believe this to be a bug. Did you ever get this sorted out?
  5. GiannosC_3CX
    GiannosC_3CX Guest
    Hi there,
    Did you use supported browsers? (Chrome, EDGE and Firefox)
  6. noord
    Nov 25, 2015
    32
    Thanks for your quick reply.
    Yes, I do. I also tried different browsers etc.
    After running the Firewall Test (which is the easiest way to restart all services :)), logging continues normally from the point where the services restart.
  7. Telcreek
    Dec 30, 2016
    27
    I wish to add I have this issue as well. I have logging set to Medium and keep for 3 days. Activity log is empty until I restart services and like noord, I use the firewall checker to do so. Running V15.0.62928.5 on Linux, hosted on AWS. Same issue with Chrome and FF.
  8. choimarc
    Feb 19, 2014
    78
    8
    I have the same issue since I installed 3CX V15 linux edition.
  9. choimarc
    Feb 19, 2014
    78
    8
    I have this issue ! Did you find a solution ?
    Thanks.
    Marco
  10. noord
    Nov 25, 2015
    32
    No, this bug is still present, also in v15.5
    It's really annoying. After you clear/purge the log file it runs again for a few days and then stops again.
  11. choimarc
    Feb 19, 2014
    78
    8
    I have installed tcpdump on the 3cx linux box. With WinSCP, I can download the file to my machine and at least use wireshark to know what's going on... Until they fix it :)
  12. Telcreek
    Dec 30, 2016
    27
    I am presently on a PRO license v15.5.5 and it's been ok for some weeks now. I am on a low level log with 3 day backup.
  13. choimarc
    Feb 19, 2014
    78
    8
    I'm using a PRO license also bu i'm on version 15.0.0.
    Thanks.
