V15 template handset/handfree volume gain
Discussion in '3CX Phone System - General' started by cspec, Oct 6, 2016.
  1. cspec
    Oct 6, 2016
    I am trying to hunt down the last issue we are having with 3CX v15. All of my user are complaining that the recipient of a phone call can hear a lot of background noise and also the caller breathing. We are on Yealink T42, T46 and T48 all with updated firmware.
    i fixed the issue by going into the phone UI itself and changing the following lines:
    voice.handfree_send =0
    voice.handset_send =0
    voice.headset_send =0
    This seems to have fixed the issue across the board.
    Now my issue is that we use templates throughout the entire company, 100+ users. I added those three lines into my template because in the v15 templates, it's not there. When I reprovision a phone with the new template, those three settings do not change in the phone. I have added it in the same spot under the Voice header in the template from referring back to the old template and still do not see any change.
    Am I missing something somewhere or does it need to be in a different location on the template? Any help would be aprreciated.
  2. cspec
    Oct 6, 2016
    I found my solution if anyone else is having this problem.
    Lines had to be added under the Phone Features Header between call waiting and intercom.
