V15 upgrade - Call costs
Discussion in '3CX Phone System - General' started by daktur, Feb 19, 2017.
  1. daktur
    daktur New Member
    Oct 15, 2015
    230
    8
    I have checked after restoring my v14 backup on v15 installation and looks like call costs were not imported.
    When I try to import them manually it does not accept multiple costs with same name like in v14.
    Anyone aware of it? Is this a real issue?
    Thanks.
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi daktur,
    We replicated several times this issue (restore from V14 to V15) and the call cost values are imported normally.
    In V15 you can add a call cost with the same name but not the same prefix. You can only have one prefix with one cost.
  3. Nkosana
    Jan 24, 2017
    7
    Hi Giannos,
    That is not the case, it refuses to add call cost with the same name.
    In my case I had to use numbering to differentiate to keep the same name.
    However I'm stil struggling to get the correct call cost even after I had setup my call rates correct.
    Do we need to delete all the default call rates first ?
    i
