V15 upgrade freezing on restore backup
Discussion in '3CX Phone System - General' started by pjk, Jul 23, 2016.
  1. pjk
    pjk
    Apr 17, 2015
    9
    I am attempting to upgrade to V15 and it is freezing on the restore backup step. Any ideas what can be causing this?
  2. kustek
    Feb 3, 2011
    Exact same problem here, done it 3 times now, dont know how to fix. any ideas?
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,367
    83
    As a test, try extracting the .zip file you have using the Windows Unzip/Extract option. I ran into this once and it turned out to be a corrupt .zip Backup File.
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Please be sure that you can resolve downloads.3cx.com and erp.3cx.com.
    Seems that this is your issue.
