v15 where is private phonebook stored
Discussion in '3CX Phone System - General' started by dab, Jan 23, 2017.
  1. dab
    dab
    Nov 1, 2009
    67
    Can someone tell me where the private phonebook is stored and how I can deploy the private phonebook to a Yealink T48G? It's working fine on 3CXPhone on Windows and Android but not on Deskphone.
    Thanks in advance
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,319
    531
    Hello @dab
    the personal phonebook of a 3CX client is stored in the 3CX server database but can not be deployed on an IP phone. It is specifically for the 3cx clients
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
    http://%webserver_IP%/provisioning/%PROVFOLDER%/yealink_phonebook.xml
    C:\programdata\3CX\Instance1\Data\Http\Interface\provisioning\%PROVFOLDER%/yealink_phonebook.xml
    Login to Phone, Directory Tab, Remote Phone Book
    Set the URL here and an update interval in seconds. I have mine set to 21600 which is 6 hours.
    Any change to a contact or extension updates this file.
  4. dab
    dab
    Nov 1, 2009
    67
    Thanks Craig, but this is the path to the company phoenbook or not?
  5. craigreilly
    Feb 1, 2012
    3,530
    298
    Oh I see - the items you add to the phonebook from the soft client and do not select 'Add To Company Phonebook' ?
    I do see them added to my other clients... I'm going to guess these are in the database somewhere and not an XML File.
