V15 Windows Client - Drops Wifi Hub
Discussion in 'Windows' started by DanielRainbow, Mar 29, 2017.
  1. DanielRainbow
    Mar 29, 2017
    Hi, I'm using version 15 from my laptop and when i load, my home wifi dies each time. The same issue happens when i try to run the app on my Samsung mobile through the home wifi. Any ideas on what i could try, the hub is a Zyxel NBG4604. Thanks in advance
