v15 with Mikrotik Router
Discussion in '3CX Phone System - General' started by craigreilly, Jan 21, 2017.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,569
    302
    I was on v14 until today. We didn't seem to be having issues on v14 - atleast nobody mentioned anything to me. When I ran the firewall checker on v15 - some RTP ports failed as "full cone test fail" and others "not reachable". The strange part about this is that the ports change on every test. This time, ports 9002, 9003, 9004 might fail and the next 9025,9026,9027,9030,9040, etc.
    Also, voice in and out is working fine on the Flowroute trunk - as well as remote extensions.
    SIP service is disabled on the Mikrotik, RTP Ports 9000-9255 on UDP forwarded. Also outbound NAT is setup so all traffic from PBX is seen as the Static Public IP setup in 3cx.
    Any one with experience with Mikrotik know what to check.
  2. dab
    dab
    Nov 1, 2009
    67
    For me it's working fine.
    Before Firewalltest I have to remove a src-list filter which in the normal case only my voip provider admits to talk.
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    I'm using several RB2011UiAS-2HnD all running on F/W v6.38.1 and no problems with firewall checker at all.
    This are the NAT filter rules I am using:
    Code:
    [admin@MikroTik] /ip firewall nat> print
    Flags: X - disabled, I - invalid, D - dynamic
     0    ;;; defconf: masquerade
          chain=srcnat action=masquerade out-interface=ether1
     1    ;;; 3CX Phone System
          chain=dstnat action=dst-nat to-addresses=IP-PBX protocol=tcp in-interface=ether1 dst-port=5060 log=no log-prefix=""
     2    chain=dstnat action=dst-nat to-addresses=IP-PBX protocol=udp in-interface=ether1 dst-port=5060 log=no log-prefix=""
     3    chain=dstnat action=dst-nat to-addresses=IP-PBX protocol=udp in-interface=ether1 dst-port=9000-9255 log=no log-prefix=""
     4    chain=dstnat action=dst-nat to-addresses=IP-PBX protocol=udp in-interface=ether1 dst-port=9256-9499 log=no log-prefix=""
     5    chain=dstnat action=dst-nat to-addresses=IP-PBX protocol=tcp in-interface=ether1 dst-port=5090 log=no log-prefix=""
     6    chain=dstnat action=dst-nat to-addresses=IP-PBX protocol=udp in-interface=ether1 dst-port=5090 log=no log-prefix=""
     7    chain=dstnat action=dst-nat to-addresses=IP-PBX protocol=tcp in-interface=ether1 dst-port=5000 log=no log-prefix=""
     8    chain=dstnat action=dst-nat to-addresses=IP-PBX protocol=tcp in-interface=ether1 dst-port=5001 log=no log-prefix=""
    Hope this helps.
    BTW: All systems are running on Windows 10, not on Debian.
    #3 complex1, Jan 22, 2017
  4. craigreilly
    Feb 1, 2012
    3,569
    302
    Here is mine. The only difference I see is I have a dst-address of my PBX Public IP Address, and my outbound rule is slightly different. Running Server 2012. Mikrotik CCR-1009.
    I did try moving the 9000 ports to its own rule - but no difference.
    Code:
    chain=dstnat action=dst-nat to-addresses=192.168.3.230 protocol=udp
          dst-address=Public-IP dst-port=5060,9000-9500,5090 log=no
          log-prefix="SIP"
    chain=dstnat action=dst-nat to-addresses=192.168.3.230 protocol=tcp
          dst-address=Public-IP dst-port=5060,5061,5090,80,443 log=no
          log-prefix=""
    chain=srcnat action=src-nat to-addresses=Public-IP
          src-address=192.168.3.230 out-interface=WAN log=no log-prefix=""
    #4 craigreilly, Jan 22, 2017
  5. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Each in separate line?
  6. complex1
    Jan 25, 2010
    814
    49
    I can’t use dst-address because I have a Dynamic WAN address.
    What if you temporarily disable all your rules and add the rules I’m using, just for test?
    Is that possible?
  7. craigreilly
    Feb 1, 2012
    3,569
    302
    We are about 24/7 - never know when folks will log in. So, I can not disable other rules. But I have moved RTP to its own line with no change.
    Also sent you a PM with a wireshark on a failed port... if you have time. Thanks.
  8. craigreilly
    Feb 1, 2012
    3,569
    302
    As I mentioned: "I did try moving the 9000 ports to its own rule - but no difference."
    The system seems to work fine and worked fine on v14. I'm just trying to figure this out... just in case. Mikrotik is on 6.38.1
  9. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    What version is router firmware, you are running.
    I have over 100 3CX installations, all using various Mikrotik routers, including cloud solutions. I have used various firmware versions, latest 6.37.4 (bugfix). See also: https://www.3cx.com/community/threa...t-working-remotely-with-3cx-v14sp3-pbx.46768/ -- it describes another issue, related to MSS size of TCP packets, but there is a solution for Mikrotik routers how to fix.
    I really doubt the problem is related to Mikrotik router itself, your configurations should be working. Restart the router, if you haven't. Do you have another router in front of Mikrotik (from Internet provider, etc.)?
    #9 eagle2, Jan 23, 2017
  10. eagle2
    Apr 27, 2011
    1,085
    11
    I've made some tests on several on my 3CX installations -- yes version 15 SP4 firewall checker reports an error, nevertheless all these PBXs are in production and are working normally. I guess this is a kind a bug in 3CX version 15, as in the same time, on the same cloud router,version 14 PBXs firewall checker passes OK.
  11. datamerge
    datamerge New Member
    Nov 19, 2014
    181
    25
    I can also attest to using 3CX behind Mikrotik routers with no issues. Interesting #eagle2 you had issues with Mikrotik. I had a client on v15 on an Audiocodes router and I had the same issues with various random ports failing. I put it down to an undersized nat table. When I replaced the router with a Mikrotik RB750G3 on 11.37.1 the test passed first time.
    #CraigReilly. I use the ruleset exactly the way you do on all my Mikrotiks. That is perfectly valid. I can't think why you would have an issue. I am wondering whether it is the CCR. You might want to check the CPU usage on the cores as CCRs are known to have some issues with multithreading and you may have a core getting bound up.
    Just a guess.
  12. craigreilly
    Feb 1, 2012
    3,569
    302
    I tried setting the MSS to the lower value for inbound and outbound TCP traffic. No dice.
    I am on latest release 6.38.1
    Its Monday - bound to be a lot of phone calls - lets see how 3cx v15 handles things.
  13. craigreilly
    Feb 1, 2012
    3,569
    302
    I missed this first time around today. thanks for reporting back. I feel better about my install now.
  14. datamerge
    Nov 19, 2014
    181
    25
    You don't use any connection rate throttling do you?
    I use this for TCP limits, but if you had a UDP rule like this you would get the same issue. The following rules are in my router to limit the number of connections to a given IP address to 10/s initially then 5/sec after the first second. I put this in because of that abomination called Windows 10 update.
    add action=accept chain=forward connection-state=new dst-limit=5,10,dst-address/1m40s out-interface=ether1-Internet protocol=tcp
    add action=drop chain=forward connection-state=new out-interface=ether1-Internet protocol=tcp
  15. craigreilly
    Feb 1, 2012
    3,569
    302
    no rate limiting...
    -some filter rules to prevent hacking attempts - which I turned off during testing .
    -a mangle rule to set DSCP.
  16. craigreilly
    Feb 1, 2012
    3,569
    302
    • testing port 9025... done
    • testing port 9026... full cone test failed
    • testing port 9027... full cone test failed
    • testing port 9028... full cone test failed
    • testing port 9029... done
    on 6.38.5 getting just 3 these fail. But next test, will be other ports.
    However, an upgrade on Mikrotik to 6.39.1 and no failed ports - with ZERO changes to the Configuration.
