v15 - Yealink phone keep restarting
Discussion in '3CX Phone System - General' started by sanketgroup, Oct 13, 2016.
  1. sanketgroup
    Jun 28, 2012
    97
    Hello
    I upgraded to v15 server.
    We also bought 10 Yealink phones (T21-E2).
    I plugged those new phones in network. 3cx detected those phone and added them as new extension.
    (by clicking on "add ext" under phone section.
    It restarts phone. Phone gets connected to server for around 25 seconds and then automatically restarts by it self.
    and it happens again and again.
    I do not understand why it is restarting.
    This happens only when provisioning has been set. If i make factory reset, phone stays on.
    But as soon as i provision it from 3cx it keeps restarting.
    This happens in all my new T21-E2 phones. Firmware is new (52.80.0.130)
    Please help me to resolve this.
    following is one extension log:
    10/14/2016 12:59:45 AM - - Deleted ADS (MWI.ADS(6050)) for <sip:728@192.168.3.30:5060>; count = 66 subscriptions now
    10/14/2016 12:59:45 AM - Destroying ADS MWI.ADS(6050)
    10/14/2016 12:59:45 AM - Endpoint Extn:728 has removed contact <sip:728@192.168.3.30:5060>
    10/14/2016 12:59:45 AM - [CM504002]: Endpoint Extn:728: a contact is unregistered. Contact(s): []
    10/14/2016 12:59:45 AM - There's no contact records found for DN 728
    10/14/2016 12:59:45 AM - Look for contact: <sip:728@192.168.3.30:5060> has found nothing
    10/14/2016 12:59:45 AM - Contact is not found in database: aor=728 contact=sip:728@192.168.3.30:5060;total found=0
    10/14/2016 12:59:45 AM - Removing contact from database: aor=728 contact=sip:728@192.168.3.30:5060;total found=0
    10/14/2016 12:59:45 AM - Contact record (cid = 0) is not found
    10/14/2016 12:59:45 AM - No contacts found for AOR sip:728@192.168.2.13
    10/14/2016 12:59:45 AM - MWI.SrvSubscr(6052){728@192.168.2.13:5060} has been terminated
    10/14/2016 12:59:45 AM - MWI.SrvSubscr(6052){728@192.168.2.13:5060}Ready t1:07 AM 10/14/2016o send: MWI Send Req NOTIFY from 0.0.0.0:0 tid=9566206cd75c9873 Call-ID=0_3010833795@192.168.3.30:
    NOTIFY sip:728@192.168.3.30:5060 SIP/2.0
    Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---9566206cd75c9873;rport
    Max-Forwards: 70
    Contact: <sip:728>
    To: "CCTV"<sip:728@192.168.2.13:5060>;tag=1051507408
    Call-ID: 0_3010833795@192.168.3.30
    CSeq: 3 NOTIFY
    Subscription-State: terminated;reason=timeout
    Event: message-summary
    Content-Length: 0
    10/14/2016 12:59:45 AM - Terminating MWI subscription MWI.SrvSubscr(6052){728@192.168.2.13:5060} of Dev(1016747115):[sip:728@192.168.3.30:5060 / 728]
    10/14/2016 12:59:45 AM - Is about to delete device Dev(1016747115):[sip:728@192.168.3.30:5060 / 728]
    10/14/2016 12:59:45 AM - Is about to remove DN 728
    10/14/2016 12:59:45 AM - Is about to remove line 728@192.168.3.30:5060
    10/14/2016 12:59:45 AM - Contact is found; cid = 2966151753
    10/14/2016 12:59:45 AM - Remove registration: aor=728 contact=sip:728@192.168.3.30:5060; id=171
    10/14/2016 12:59:45 AM - Removing contact from database: aor=728 contact=sip:728@192.168.3.30:5060;total found=1
    10/14/2016 12:59:45 AM - AOR sip:728@192.168.2.13 is removing contact [<sip:728@192.168.3.30:5060>]
    10/14/2016 12:59:45 AM - Found 1 contact(s) for AOR sip:728@192.168.2.13
    10/14/2016 12:59:45 AM - Caller "CCTV"<sip:728@192.168.2.13:5060>;tag=123568032 has been authenticated successfully from IP 192.168.3.30
  2. sanketgroup
    Jun 28, 2012
    97
    One more thing:
    Even if i do factory reset, phone keeps restarting.
    If i remove network cable from phone then only it stays on.
    I remember that i have once removed Ext assigned to this mac.
    Is it possible that 3cx is keep sending delete provision command to that mac address continuously ?
  3. sanketgroup
    Jun 28, 2012
    97
    Issue is confirmed !
    If we delete any extension which is setup with Yealink (T21-E2), no matter what you do that phone will always keep restarting.
    Even if you factory reset the phone, it will still keep restarting.
    Why? because once ext deleted from 3cx, it sends clear provisioning commands to that MAC.
    Bug: 3cx keep sending this command to all MAC address which are deleted from 3cx as ext.
    I tried with one more total new phone which was never setup in 3cx. I provisioned it and it is never restarting.
    Because Ext (or that new mac) has never been deleted from 3cx.
    As soon as i deleted ext of that mac from 3cx, that phone started with same issue.
    3cx pls help urgently. We are not able to use our 8 phones (since we deleted 8 ext)
  4. andreaschr
    andreaschr Support Team
    Oct 26, 2015
    93
    6
    Hi sanketgroup,
    We try to reproduce your issue and we can not .
    3CX never sends "delete provision command to the phone" because we don't have that type of functionality.
    The SIP NOTIFY which is sent in the description is just a notify to the client that subscription to MWI service (Voice Mail) is expired and terminated.
    Please open a support ticket so we can help you solve this issue.
  5. sanketgroup
    Jun 28, 2012
    97
    I went to phone's webpage and deleted auto provisioning link.
    Then phone never restarted and works well.
    I have to manually set each of those IP phone. And never had issue.
    If i enter auto-provisioning link to 3cx then phone keeps restarting.
    Also as i tested, new phone with same ext also works well (since MAC is totally new for 3cx).
    I think only 3cx partners can open support ticket, right? I donot have logins.
  6. sanketgroup
    Jun 28, 2012
    97
    any update?
  7. Francesco Doni
    Aug 21, 2017
    5
    I discovered this problem with T48S, and this is annoying.
    Phone continuosly registered and unregistered from 3CX:
    • SIP Server/Call Manager ID: 4101
      Extension 272 is unregistered, removed contact: sip:272@172.16.20.68:5060
    • 21/08/2017 16:30:58
      Extension 272 is registered, contact: sip:272@172.16.20.68:5060
    Anyone find this problem ? If I configure phone by hand it works. The problem is only with autoprovisiong
  8. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    228
    17
    Hello @Francesco Doni,
    Please do supply me with more information. Are you using the latest firmware?Is your system up to date? Do you have the appropriate forwarding rules?
    #8 IoannisM_3CX, Aug 21, 2017
  9. Francesco Doni
    Aug 21, 2017
    5
    I've installed latest firmware on T48S (version 66.81.0.110) and I'm running latest 3CX version PRO 15.5.3849.1
    All other phone works correctly (I've some Cisco phone), and forwarding rules I think had correctly configured
    And 3cx and T48S are in same lan
  10. Francesco Doni
    Aug 21, 2017
    5
    This is a small piece of event log:
    • 21/08/2017 17:03:36
    • 21/08/2017 17:03:04
    • 21/08/2017 17:01:54
    • 21/08/2017 17:01:21
    • 21/08/2017 17:00:11
    • 21/08/2017 16:59:38
    • 21/08/2017 16:56:35
    • 21/08/2017 16:54:23
    • 21/08/2017 16:53:15
    • 21/08/2017 16:52:45
    • 21/08/2017 16:51:30
    • 21/08/2017 16:50:59
    • 21/08/2017 16:49:46
    • 21/08/2017 16:49:14
    • 21/08/2017 16:37:51
    • 21/08/2017 16:36:41
    • 21/08/2017 16:36:09
  11. IoannisM_3CX
    Aug 10, 2017
    228
    17
    I tried auto provisioning a Yealink T48S on my PBX and now after several minutes have passed, the phone is still registered and works fine.
    So i assume the problem is located somewhere in your network. Are you sure that you have configured your forwarding rules correctly, that there is nothing that can cause port blocking and also have you disable SIP ALG? Do you have any other phones that operate or not with the auto provision method?
    Though there is a highly chance that the problem is at network level or it's a configuration issue, this is always an assumption.
    In order to locate and solve the problem we will need support information, that can be extracted from Dashboard>>Generate Support Info after you have set your logging level to Verbose (Dashboard>>Activity Log>>Settings) as well as and a capture too.
    Do you have the ability to open a ticket in our ticketing support system?
    Thank you
  12. neville
    neville New Member
    Apr 23, 2012
    202
    33
    I recently had a similar situation with some random Yealink T23G's on a new installation replacing an older Cisco system and reusing old cable. It ended up being a cable issue. The power would drop enough to drop the Ethernet connection but not reboot the phone. It would show as unregistered and then registered in the log. We put them on power supplies and the issue stopped.
  13. daneke
    May 8, 2017
    46
    I saw this when I took a 10 mile walk. It was my Android extension that was registering and unregistering as I walked by various WiFi hotspots.
  14. Francesco Doni
    Aug 21, 2017
    5
    All my phone have external power supply, I don't use POE, so I think is not a power problem. Also phones and 3CX are on the same VLAN.
    The strange is that ff I deconfigure autoprovisioning, phone works correctly
  15. IoannisM_3CX
    Aug 10, 2017
    228
    17
    Then the only way to assist you is by providing us with support info files and capture.
    Thank you
  16. Francesco Doni
    Aug 21, 2017
    5
    I don't know how open a case ... I will try to find the way ..
  17. IoannisM_3CX
    Aug 10, 2017
    228
    17
    Send me a p.m. with your support info and a capture
    Thank you
  18. Shahid Parwaiz
    Aug 24, 2017
    We have 3CX V15 working on Windows 7 , Facing below issue , even last time almost 100 phones have been unregistered all of a sudden .
      Extension 55515 is unregistered, removed contact: sip:55515@xx.xxx54.42:1252
      Extension 99999 is unregistered, removed contact: sip:99999@xx.xxx.54.42:1281
      Extension 55555 is unregistered, removed contact: sip:55555@xx.xxx.54.42:1262
      Extension 80701 is registered, contact: sip:80701@xx.xxx.138.201:5060
      Extension 10000 is unregistered, removed contact: sip:10000@xx.xxx.54.42:1290
      Extension 71847 is registered, contact: sip:71847@xx.xxx.122.248:1601
    Please support , this issue is very much weird .
