V3.6 (14.0.57)-One way audio
Discussion in 'Android' started by karlinoz, Dec 9, 2016.
  1. karlinoz
    Apr 14, 2015
    6
    Device Info
    Phone Model: Samsung Galaxy S7 Edge
    Firmware Version:
    AP: G935FXXU1BPJG
    CP: G935FXXU1BPK4
    CSC: G935FXSA1BPHC
    Model: SM-G935F​
    Android Version: 6.0.1
    Issue Info
    Handset: No audio in earspeaker. Audio is only being delivered one-way. The person on the other end of the call can hear audio from the device's mic but the speaker in the device does not play audio from the other end (complete silence).
    The handset speaker does work because the user can take Mobile calls on the device.
    Happens on both internal and external calls.
    • Have tried switching Audio codecs on the device, tried setting G722, G711Law, G711uLaw, GSM as the primary codec in turn. No effect.
    • Tried setting TCP Transport option to on - no effect
    • Tried uninstalling and reinstalling the app - no effect
    • Tried reprovisioning the phone - no effect
    • In the 3CX Server Manager (PBX) tried setting the option Extensions->[User's Extension]->Other(tab)
      PBX Delivers Audio option to ON and both Supports Re-Invite and Support 'Replaces' header to OFF. - no effect
    • Tried switching to device speaker (speaker icon on 3CX app) - no effect
    Can anyone tell me what other steps I can take in troubleshooting this please? Are there any tools I can use and/or logs I can check?
    TIA
    Karl
    10,758
    286
    What are you using for a data connection? If it has just been 3/4G up to this point then turn that off and try Wifi. Try this from both a remote hotspot and on the same LAN as the 3CX server. Try using enabling and using the tunnel to see if that makes a difference. If it does then it suggests some ports carrying the audio packet are being blocked somewhere as the tunnel sends all through one port (with the possible exception of Presence information).
  3. ALuisPV
    Mar 7, 2016
    28
    Hi karlinoz ,
    I had this same issue a time ago with 3CX Phone for Android (I don't remember the concrete version). I tried many configurations but any of these configurations solve the problem.
    Finally I tried deleting files associated to the 3CX Phone for Android App (from "Settings" --> "Applications" in my phone). After this, I uninstalled completily the 3CX Phone for Android App. Once uninstalled, I installed again the App from Google Play. I provisioned again with the welcome email and the problem was solved.
    I didn't know what could be the reason of the issue in my case (similar to your case) but doing this, I fixed the problem. You can try to do it (you don't lose anything).
    Best Regards.
  4. karlinoz
    Apr 14, 2015
    6
    Thanks for your response leejor. All my testing was done on WiFi. Good point, I can try over 4G and see if using the tunnel makes any difference.
  5. karlinoz
    Apr 14, 2015
    6
    Thanks for your response too ALuisPV, I did uninstall/reinstall the app but didn't clear the data and cache first. I'll give that a go.
  6. ALuisPV
    Mar 7, 2016
    28
    great karlinoz!. I'll wait for your news.
