v3572 DR Transfer music?
Discussion in '3CX Phone System - General' started by RobLloyd, Dec 20, 2007.
  1. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Since my thread was locked in the v5 beta section here goes again.
    What's up with the DR transfer to an extension with complete silence? Any idea when this will be fixed?
  2. giovanni0826
    Apr 6, 2007
    53
    i would like to know as well.
  3. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    Same Problem :(
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,913
    219
    We are going to make a separate patch for this and upload asap.
    It was not actually implemented, and we wanted to fix VOIP provider issues first. Its on our TO DO list and on my Xmas wish list :)
  5. AldoLinares
    Nov 12, 2007
    135
    Thanks as always Nick :)
  6. Nick Galea
    Jun 6, 2006
    1,913
    219
    Well thanks to you guys actually for pointing out these things. :)
  7. Spitz
    Nov 23, 2007
    26
    Phew hope the fix will be soon!
  8. giovanni0826
    Apr 6, 2007
    53
    Nick,
    until the issue is resolved how about send me a wav file stating there will be a brief silence while you are transferred. something better scripted though and with the same female vocals thats on the prompts now to make it all uniformed. if you can get that asap i can live with the issue for a while.
  9. Nick Galea
    Jun 6, 2006
    1,913
    219
    To download a build with music on hold during transfer from DR:
    http://www.3cx.com/downloads/3CXPhoneSystem5_3762.exe
    Gicleemedia - not sure which oustanding VOIP provider issues you are referring to - we have tested against all our supported providers and it works well. However, we have made additional documentation on how to configure it with unsupported VOIP providers. Basically, if you are getting source identification errors, review this FAQ how to fix it:
    http://www.3cx.com/support/source-identification-err-2.html
    Hope that helps!
  10. AldoLinares
    Nov 12, 2007
    135
    gicleemedia
    Did you have a pay version of V5?
  11. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    This worked! Thank you for fixing it. I feel I can now put this in production environments.
