v4 and g729
Discussion in '3CX Phone System - General' started by Urbok, Nov 1, 2007.
  1. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    is 3cx v4 beta working with g729? can I install v4 to test g729 codec?
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Hi.
    g729 is only in paid version.
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Which kind of tests, related to G729, you are planning to perform against version 4?
  4. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    in italy ADSL with 256kbit upload is the standard in hi speed comunication.
    Provider as Eutelia uses g729 as standard (for bandwidth usate propouse).
    I've trived G711 and GSM with 3cx but with bad results (g711 too much
    bandwidth and GSM too poor quality....)
    I need to test G729 to complete the tests (and compare Eutelia directly connected VS 3cx.)
  5. weebnuts
    Sep 13, 2007
    37
    btw how do you know which codec the system is actually using?
  6. SY
    3CX Support
    Jan 26, 2007
    1,825
    Do you expect better quality from G279?
  7. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    from g729 I expect better voice quality (thanks to the voice predict feature of this codec) with less bandwith (8kbps each channel)
    I'm monitoring the router with a packet sniffer and I'm calculating the amount of voice packets during conversation.
    actualy I'm using GSM with poor voice quality.
    Codecs supported by Eutelia is: G711 G729 GSM. No ILBC... I was courous also about the performance of this codec.....
  8. SY
    3CX Support
    Jan 26, 2007
    1,825
    Do you expect better performance from G729?
  9. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    I expect also more CPU usage on the server with G729...
  10. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    I expect higher cpu usage but better voicequality performance with less bandwidth.
  11. todd
    Jun 9, 2007
    35
    me too!
