v5.0.3790.0 FORWARD
Discussion in '3CX Phone System - General' started by kirimis, Jan 9, 2008.
  1. kirimis
    Oct 16, 2007
    43
    Please help it is very important, i updated version 3 with v5.0.3790.0 and tranfer call is not working both with internals and also pstn lines
    can anybody has any suggestions?
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,939
    250
    Server status log and hardware that you are using.....
  3. kirimis
    Oct 16, 2007
    43
    tranfer error
    the log shows :"MS004001] C:47.1: Can't send RTP stream to 1 destination unreachable
    09:43:12.280 CallCtrl::eek:nLegConnected [CM503007]: Call(47): Device joined: sip:171@100.100.100.149:5060
    09:43:12.265 CallCtrl::eek:nLegConnected [CM503007]: Call(47): Device joined: sip:111@100.100.100.150:5060
    09:43:10.047 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(47): Calling: Ext:171@[Dev:sip:171@100.100.100.149:5060]
    09:43:09.968 CallCtrl::eek:nIncomingCall [CM503001]: Call(47): Incoming call from Ext.111 to [sip:171@100.100.100.253]
    09:43:02.798 Call::Terminate [CM503008]: Call(46): Call is terminated
    I am using Patton SN-4638 5-port ISDN/BRI and GrandStream GXW-4104
    and as phones i am using "onevoip" sip device
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Re: tranfer error
    Could you please send me a Data/Logs/3CXMediaServer.trace.log and Data/Logs/3CXPhoneSystem.trace.log files for described scenario?
    my e-mail box is "stepan"
  5. kirimis
    Oct 16, 2007
    43
    TRANSFER REPLY
    sorry i cannot i unistalled 5 and i installed again v3.1.2434.0
    i could not work with 5 and a was in a rash since the 3cx is active and playing as the only RBX in my office.
    i had other problem too with 5
    first i tries to upgrade from v3.1.2434.0 to 5. instllation finished and everything was lost inside, it was like having a clean istallation. then i tried to restore a backup and i got a message like"error time out 500 at line 101" and then nothing was playing correctly. i unistalled the 5 , installed 3 restore backup again the same. finally i insttaled clean 5 and everything form the start and all plaied well except tranfering that is the story. i spend all lot of time for this yesterday from 17:00 till 21:00 and the from 22 to 2:30 am and again all morning today. i am too optimist to make 3cx for me working perfectly and i am persistand on that but i need help for these bugs . thank you for your immediate response. please tell me if must make something else.
  6. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    I will try and replicate this and I will send my results here. Can you send us the current configuration you have on your Version 3 PBX? This way I will try and replicate your problem using exactly that same variables you are using.
    Send it to me on nb@3cx.com
    Regards
  7. kirimis
    Oct 16, 2007
    43
    REPLY
    Can you guide me on who to sent you the current configuration?
    what files do you need or other data?
  8. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    I need the backup file of the pbx that gave you problems.
    We are in a situation where we need to evaluate whether there is a problem with the backup file itself which is causing these issues whilst you are migrating from version 3 to version 5.
    rgds nicky
  9. kirimis
    Oct 16, 2007
    43
    REPLY
    ok i will try to sent it tomorrow
  10. kirimis
    Oct 16, 2007
    43
    i tried to contact you through mail but i got no answer. my backup is 16.mb is there other way to sent it except email?
  11. forumpl
    Jan 19, 2008
    It's my problem too. I install v.5 on v.3. With Grandstream I can trasfer call with TRANSFER botton. With IP 301 TRANSFER is not working!! I have to return to v.3?? I hope no...
