V5 and "silent voice mail" on internal calls
Discussion in '3CX Phone System - General' started by npiersma, Dec 9, 2007.
  1. npiersma
    Dec 30, 2006
    55
    Hi all,
    Just updated to version 5 from version 3, not a very smooth transition. Had a lot of problems with the database. We did an inplace upgrade and none of the phones were working anymore. I figured, let's delete one extention and recreate it, no go....deletion went fine, re-adding gave a "database duplicate object"... I did a clean install and restored the database.... Same problem. So i thought, let's start over, a clean config. So I reconfigured my extentions and voip providers. Everything works fine now... But I've got one issue left. Voicemail doesn't seem to work anymore. (I did register my key).
    when I call internally to an ext that's forwared to a VM I get this message:
    19:31:11.755 MediaServerReporting::SetRemoteParty [MS210003] C:7.1:Answer provided. Connection(transcoding mode):82.95.255.231:1260(1261)
    19:31:11.755 CallCtrl::eek:nLegConnected [CM503007]: Call(7): Device joined: sip:127@10.0.3.1:5060
    19:31:10.787 CallCtrl::eek:nLegConnected [CM503007]: Call(7): Device joined: sip:
    19:31:10.787 CallCtrl::eek:nRerouteReq [CM503005]: Call(7): Forwarding: IVR:RecordMessage@[Dev]
    19:30:55.723 Extension::printEndpointInfo [CM505001]: Ext.125: Device info: Device Identified: [Man: GrandStream;Mod: GXP-2000;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.4.18] Transport: [sip:10.0.1.71:5060]
    19:30:55.723 CallCtrl::eek:nAnsweredCall [CM503002]: Call(7): Alerting sip:125@10.0.9.2:5060;transport=udp
    19:30:55.661 MediaServerReporting::SetRemoteParty [MS210006] C:7.2:Offer provided. Connection(by pass mode): 10.0.3.1:16386(16387)
    19:30:55.457 MediaServerReporting::SetRemoteParty [MS210000] C:7.1:Offer received. RTP connection: 10.0.3.1:16386(16387)
    19:30:55.457 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(7): Calling: Ext:125@[Dev:sip:125@10.0.9.2:5060;transport=udp]
    19:30:55.457 Extension::printEndpointInfo [CM505001]: Ext.127: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA922-5.1.15(a)] Transport: [sip:10.0.1.71:5060]
    19:30:55.395 CallCtrl::eek:nIncomingCall [CM503001]: Call(7): Incoming call from Ext.127 to "125"[sip:125@pi31voip1.piersma.net]
    When I call from a cell to the same extention I get this log (and a working voicemail)
    19:38:39.129 LineCfg::getInboundTarget [CM503010]: Inbound out-of-office hours' rule for LN:10003 forwards to DN:801
    19:38:39.129 Call::Terminate [CM503008]: Call(8): Call is terminated
    19:38:39.114 LineCfg::getInboundTarget [CM503010]: Inbound out-of-office hours' rule for LN:10003 forwards to DN:801
    19:38:39.098 LineCfg::getInboundTarget [CM503010]: Inbound out-of-office hours' rule for LN:10003 forwards to DN:801
    19:38:20.130 LineCfg::getInboundTarget [CM503010]: Inbound out-of-office hours' rule for LN:10003 forwards to DN:801
    19:38:20.114 MediaServerReporting::SetRemoteParty [MS210003] C:8.1:Answer provided. Connection(transcoding mode):82.95.255.231:1274(1275)
    19:38:20.114 CallCtrl::eek:nLegConnected [CM503007]: Call(8): Device joined: sip:0614248182@80.69.83.64
    19:38:18.974 CallCtrl::eek:nLegConnected [CM503007]: Call(8): Device joined: sip:
    19:38:18.974 LineCfg::getInboundTarget [CM503010]: Inbound out-of-office hours' rule for LN:10003 forwards to DN:801
    19:38:18.958 CallCtrl::eek:nRerouteReq [CM503005]: Call(8): Forwarding: IVR:RecordMessage@[Dev]
    19:37:48.850 CallCtrl::eek:nAnsweredCall [CM503002]: Call(8): Alerting sip:125@10.0.9.2:5060;transport=udp
    19:37:48.741 CallCtrl::eek:nAnsweredCall [CM503002]: Call(8): Alerting sip:108@10.2.16.5:5060;transport=udp
    19:37:48.741 MediaServerReporting::SetRemoteParty [MS210002] C:8.3:Offer provided. Connection(transcoding mode): 82.95.255.231:1278(1279)
    19:37:48.522 MediaServerReporting::SetRemoteParty [MS210002] C:8.2:Offer provided. Connection(transcoding mode): 82.95.255.231:1276(1277)
    19:37:48.319 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(8): Calling: RingAll:801@[Dev:sip:108@10.2.16.5:5060;transport=udp, Dev:sip:125@10.0.9.2:5060;transport=udp]
    19:37:48.303 MediaServerReporting::SetRemoteParty [MS210000] C:8.1:Offer received. RTP connection: 80.69.83.64:19534(19535)
    19:37:48.288 Line::printEndpointInfo [CM505003]: Provider:[AL 3319246] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Adaline_NL_PBX] Transport: [sip:10.0.1.71:5060]
    19:37:48.288 LineCfg::getInboundTarget [CM503010]: Inbound out-of-office hours' rule for LN:10003 forwards to DN:801
    19:37:48.257 CallCtrl::eek:nIncomingCall [CM503001]: Call(8): Incoming call from 0614248182@(Ln.10003@AL 3319246) to [sip:801@pi31voip1.piersma.net:5060]
    19:37:47.975 LineCfg::getInboundTarget [CM503010]: Inbound out-of-office hours' rule for LN:10003 forwards to DN:801
  2. npiersma
    Dec 30, 2006
    55
    Well, just an update.
    I've managed to get vmail to email working, so we can do business. But leaving an internal vmail for an extention isn't working. Same goes for listening to voicemails via 999. The extention does get connected when dialing 999. but stays yellow in the status window.
    125 00:05:22
    Status: Connected: (127)
    I did play around with "pbx delivers audio" but that doesn't seem to matter.
    Anyway, at the moment not a very nice stable version, but we can manage.
  3. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    You sure it's not a firewall issue?
  4. npiersma
    Dec 30, 2006
    55
    Dear Pentangle,
    We're pritty sure it's not a firewall issue. Phones are connected in one VLAN (voice) 3CX server is installed in other VLAN (SeRVERS). There connected to Cisco 3700 series switches with l3 routing, but no filtering is done.
    Niels
  5. nateb
    Oct 19, 2007
    68
    voice mail
    how did you fix the voice mail problem? i think i'm having the same problem.
  6. kwoodrin
    Sep 7, 2007
    I'm having the same issue. Removed v3 and did a clean install of v5, then restored the database. Everything worked fine except I have no access to check voicemail anymore for any extensions. When we dial the number to check voicemail, it says "Please enter extension" and then no matter what you enter it hangs up.
    Let me know if you find anything out on this--it is very disruptive. Thanks.
  7. kwoodrin
    Sep 7, 2007
    Update, this apparently has nothing to do with Voicemail but is part of a much bigger issue where apparently v5 doesn't recognize DTMF at all. I am using GXP-2000 and have DTMF set up to be delivered "in-audio"
  8. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    I am also having this problem. this needs to be addressed immediately. I had a working production product and now I do not.
    If I am to retain this customer with this prodcut this needs to be fixed.
    I also have a problem with the Auto Attendent after the upgrade. If you delete/add/change an extension it will not allow for modifiction of the attendent.
  9. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    I have a working version of v5 with working voicemail on the LAN when using the 3CX VoIP Client. I can't hear the DTMF tones when I press the buttons, but the voicemail certainly does work.
    HTH.
  10. nateb
    Oct 19, 2007
    68
    FIXED
    ok , to fix it, manage lines, edit gateway / provider properties, then edit Gateway capabilities , check supports re-invite , and supports replace header.
    That Fixed it for me!!
