V5 BLF PSTN Line ?
Discussion in '3CX Phone System - General' started by AldoLinares, Dec 6, 2007.
  1. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    I already set up the GXP2000 for the BLF on some extensions and it's working fine, the only thing i noticed it's it gets activated only when the call its used the first time. No problem for that.
    The question that i have i tried to set up on PSTN Line 10001 and dont work, maybe BLF it's only intended for Extensions, but it's possible to watch on BLF the LINES?
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Yes, currently you can monitor only extention states with BLF. It will be expanded to monitor lines too, but later. But if you have 'Presense watcher' option for BLF (latest firmware of GXP has it) - you could monitor lines too, I suppose (actually, I didn't check it yet, but it should work).
  3. AldoLinares
    Nov 12, 2007
    135
    I try it but it gets green, but if the line it's use it continue to be green, never change color to red or something.
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi AldoLinares,
    I also test the BLF. However, it just working. The BLF status indicator are NOT in correct status at following scenario.
    Grandstream BT-200: EXT 301
    Polycom IP330: EXT 341
    Grandstream GXP-2000: EXT 473 (BLF console)
    Our testing:
    1. EXT 301 issue call to EXT 341 (Both LED inidcator for 301 and 341 are
    flash in Green color)
    2. EXT 341 pick up the call (Both LED inidcator for 301 and 341 are in Red
    color)
    3. EXT 301 hang up the call (LED inidcator for 301 in Green color, LED
    inidcator for 341 in Red color)
    15:34:00.984 Call::Terminate [CM503008]: Call(32): Call is terminated
    15:33:56.046 CallLeg::eek:nConfirmed Session 557 of leg C:32.1 is confirmed
    15:33:55.890 CallCtrl::eek:nLegConnected [CM503007]: Call(32): Device joined:
    sip:341@10.1.1.19:5060
    sip:301@10.1.1.23:5060;transport=udp
    15:33:55.875 MediaServerReporting::SetRemoteParty [MS210007] C:32.1:Answer
    provided. Connection(direct): 10.1.1.19:2230(2231)
    15:33:55.875 MediaServerReporting::SetRemoteParty [MS210001] C:32.2:Answer
    received. RTP connection: 10.1.1.19:2230(2231)
    15:33:55.875 CallLeg::setRemoteSdp Remote SDP is set for legC:32.2
    15:33:54.718 Extension::printEndpointInfo [CM505001]: Ext.341: Device info:
    Device Identified: [Man: Polycom;Mod: SoundPoint IP 330;Rev: General]
    Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent:
    [PolycomSoundPointIP-SPIP_330-UA/2.2.0.0047] Transport: [sip:10.1.1.10:5060]
    15:33:54.718 CallCtrl::eek:nAnsweredCall [CM503002]: Call(32): Alerting
    15:33:54.484 MediaServerReporting::SetRemoteParty [MS210006] C:32.2:Offer
    provided. Connection(direct): 10.1.1.23:5004(5005)
    15:33:54.468 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(32): Calling:
    Ext:341@[Dev:sip:341@10.1.1.19:5060]
    15:33:54.468 CallCtrl::eek:nSelectRouteReq Making route(s) to
    [sip:341@10.1.1.10]
    15:33:54.468 MediaServerReporting::SetRemoteParty [MS210000] C:32.1:Offer
    received. RTP connection: 10.1.1.23:5004(5005)
    15:33:54.453 CallLeg::setRemoteSdp Remote SDP is set for legC:32.1
    15:33:54.453 Extension::printEndpointInfo [CM505001]: Ext.301: Device info:
    Device Not Identified: User Agent not matched; Capabilities:[reinvite,
    replaces, able-no-sdp, recvonly] UserAgent: [Grandstream BT200 1.1.5.15]
    15:33:54.421 CallCtrl::eek:nIncomingCall [CM503001]: Call(32): Incoming call
    from Ext.301 to [sip:341@10.1.1.10]
    Our finding is, if the caller hang up the
    call first will cause the BLF status indicator in-correct stage. How about you?
  5. AldoLinares
    Nov 12, 2007
    135
    5qg4
    My phones are showing the extensions fine, if they are in use they will be red if they are idle they are green, but if a phone since the boot up of the phone never get used the led will never be green or red.
    I was asking if i can configure a PSTN Line or VOIP line to show on the BLF.
    Another strange thing is that if the phone it's not used for some time (don't know how many time) the led will go off.
  6. silentfun
    silentfun Member
    Dec 11, 2006
    364
    i have tryed latest FW on the GXP-2020 1.1.5.15 but it is realy bad.
    - BLF is like a Oracles Guess
    - is some conditions when u want to change something via web interface the phone freeze
    - it seems that it forget to refresh the registering at the PBX server. all other phones show register expired and then reregister but not the GXP with new firmware - when i try a call next mornig i can not without reboot
    - if you use other then english language u have trouble with ÄÖÜß and so on.
    - XML Applications for softbuttons don´t run
    - idle/custom screen have no status bar and not all variables u need
    - and the display texts are much too big. ok 1.1.4.17 was a bit small but hey this is too big now.
    - sometimes it have bad timeouts so if you dial fast 12345 it only accept 12 and eat the rest and u have to type again 345 and the push send or wait 4 seconds
    so i have decided to go back to 1.1.4.17 because it is stable but have no xml Appl. it run ok with V3.
    so beware of GXP-2020 1.1.5.15
    Andy
  7. archie
    3CX Support
    Aug 18, 2006
    1,299
    Sorry, forgot to mention, in case of Presence watcher you CAN monitor lines, BUT it will show only whether line is registered or not. It's the limitations of "presence" event itself. When we'll implement dialog-info for lines (and it will happen quite soon) - you will be able to monitor them with "Asterisk BLF" option and it will show calling/ringing and in-a-call states too, as it does for extensions now.
  8. AldoLinares
    Nov 12, 2007
    135
    In the newer version of the FW of the GXP2000 they changed the name from Asterisk BLF to Busy Lamp Field :)
    Also there is a new option:
    Eventlist BLF
  9. silentfun
    silentfun Member
    Dec 11, 2006
    364
    Yes they changed the name but the funktion from Grandstream GXP´s is not good for productive systems because it seems the status only get Changes of the Status - and if he don´t get the change in any scenario it show you the false state until he get an other change.
    very bad thing if you trust in the Status Lights
    Andy
