v5 bug
Discussion in '3CX Phone System - General' started by Pentangle, Dec 6, 2007.
  1. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Since there's no specific section for v5 bugs yet, this is here...
    When trying to change the default voicemail number from 999 (the UK emergency number!) to 121 (a popular voicemail number here), the interface firstly complained about me not giving a 4 digit extension, but then when I changed it to 1212 the PHP gave me this error:
    Warning: file_put_contents() [function.file-put-contents]: Only 0 of 2601 bytes written, possibly out of free disk space in C:\Program Files\3CX PhoneSystem\Data\Http\functions\configFile.php on line 130
    Warning: Cannot modify header information - headers already sent by (output started at C:\Program Files\3CX PhoneSystem\Data\Http\functions\configFile.php:130) in C:\Program Files\3CX PhoneSystem\Data\Http\admin_general.php on line 263
    ...note, unless you're trying to write a 400Gb+ file, i'm not out of disk space :)
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    May be its due to accsess rights or read-only status of that configFile.php file?
  3. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    well it's not something i've messed with - it's a virgin install of 3CX. Also, SYSTEM and Administrators both have full control of that file.
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    Ok, we'll investigate that issue.
