V5 - Cannot initiate outbound calls via Patton 4634
Discussion in '3CX Phone System - General' started by lucasasdelli, Dec 27, 2007.
  1. lucasasdelli
    Oct 28, 2007
    7
    V5 - Cannot initiate outbound calls via Patton 4632
    Hi all,
    I've successfully run 3CX V3 with Patton SmartNode 4634, but since V5 the 3CX refuses to initiate outbound calls via that router. Outbound calls via VoIP providers and all types of incoming calls are ok anyway.
    This the logged data during outbound call:
    :[CM503003]: Call(49): Call to sip:0516248148@192.168.1.1:5060 has failed; Cause: 503 Service Unavailable; from IP:192.168.1.1
    By debugging calls on Patton, no errors are highlighted and it seems that the outbound line is correctly initialized, but the call is aborted by 3CX.
    On Patton router there are two ISDN BRI from two different carriers and the 3CX does exactly the same for both. It looks like 3CX cannot detect a successfully outbound call by the router, and then it switches to the next configured provider, and with the first available VoIP provider it does place regular outbound calls.
    3CX v5.0.3752.0
    Patton SN4634 R4.2 2007-09-19 H323 SIP BRI
    Thanks in advance and best wishes for the new year
    Luca
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Luca,
    Please post the Patton config file and debug log here as well.
  3. lucasasdelli
    Oct 28, 2007
    7
    Hi Ricky,
    here the patton config:
    # SN4634/3BIS/UI #
    # R4.2 2007-09-19 H323 SIP BRI #
    # 2007-12-25T10:31:42 #
    # SN/00A0BA0311CF #
    # Generated configuration file #
    cli version 3.20
    dns-client server 192.168.1.200
    webserver port 80 language en
    snmp community public ro
    sntp-client
    sntp-client server primary 192.168.1.200 port 123 version 4
    sntp-client server secondary 193.204.114.233 port 123 version 4
    sntp-client operating-mode anycast
    sntp-client poll-interval 1800
    system hostname patton.alogica.it
    system
    ic voice 0
    low-bitrate-codec g729
    system
    clock-source 1 bri 0 0
    clock-source 2 bri 0 1
    clock-source 3 bri 0 2
    profile napt NAPT_WAN
    profile napt NAPT_eth0
    profile ppp default
    profile call-progress-tone IT_Dialtone
    pause 1 1000
    pause 2 200
    profile call-progress-tone IT_Busytone
    play 1 200 425 -7
    pause 2 200
    profile tone-set default
    profile tone-set IT_default
    map call-progress-tone dial-tone IT_Dialtone
    map call-progress-tone busy-tone IT_Busytone
    profile voip default
    codec 1 g711alaw64k rx-length 20 tx-length 20
    codec 2 g711ulaw64k rx-length 20 tx-length 20
    profile voip fax_enabled
    fax transmission 1 relay t38-udp
    profile pstn default
    profile sip default
    profile aaa default
    method 1 local
    method 2 none
    context ip router
    interface eth0
    ipaddress dhcp
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
    interface eth1
    ipaddress 192.168.1.1 255.255.255.0
    context ip router
    route 0.0.0.0 0.0.0.0 192.168.1.254 1 traffic-class local-default
    context cs switch
    national-prefix 0
    international-prefix 00
    interface isdn isdnif0
    route call dest-interface sipif0
    use profile tone-set IT_default
    interface isdn isdnif1
    route call dest-interface sipif1
    interface sip sipif0
    bind gateway sipgw0
    service default
    route call dest-interface isdnif0
    remote-party-id called-party
    address-translation outgoing-call request-uri user-part fix 10000 host-part to-header target-param none
    address-translation incoming-call called-e164 request-uri
    interface sip sipif1
    bind gateway sipgw1
    service default
    route call dest-interface isdnif1
    address-translation outgoing-call request-uri user-part fix 10001 host-part to-header target-param none
    context cs switch
    no shutdown
    gateway sip sipgw0
    bind interface eth1 router
    service default
    domain 192.168.1.199
    defaultserver manual 192.168.1.199 loose-router
    registration manual 192.168.1.199
    user 10000 authenticate password LbFCDNv4/Fk= encrypted default register
    gateway sip sipgw0
    no shutdown
    gateway sip sipgw1
    call-signaling-port 5062
    service default
    user 10001 authenticate password dZ8edXkjFnM= encrypted default register
    gateway sip sipgw1
    no shutdown
    port ethernet 0 0
    medium auto
    encapsulation ip
    bind interface eth0 router
    no shutdown
    port ethernet 0 1
    medium auto
    encapsulation ip
    no shutdown
    port bri 0 0
    clock auto
    encapsulation q921
    q921
    protocol pp
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side user
    bchan-number-order ascending
    encapsulation cc-isdn
    bind interface isdnif0 switch
    port bri 0 0
    no shutdown
    port bri 0 1
    clock auto
    encapsulation q921
    q921
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side user
    bind interface isdnif1 switch
    port bri 0 1
    no shutdown
    port bri 0 2
    clock auto
    encapsulation q921
    q921
    protocol pp
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side net
    port bri 0 2
    shutdown
    And here an ISDN debug:
    patton.alogica.it#debug isdn event 0 0 all
    patton.alogica.it#
    03:46:04 ISDN > # 128 p: 0 from CC key: 8388619 L3SetupReq
    03:46:04 ISDN > # 129 Service:Transparent cing: sub: ced: sub:
    03:46:04 ISDN > # 130 cause : Transparent
    03:46:04 ISDN > # 131 hex:04 03 90 90 A3 1E 02 85 83 6C 0D 00 80 30 35 31 31 39 39 38 32 30 33 35 70 0B 80 30 35 31 36 32 34
    03:46:04 ISDN > # 132 IE: Bearer
    03:46:04 ISDN > # 133 IE: ProgressInd
    03:46:04 ISDN > # 134 IE: CallingPartyNbr _our_MSN_number_
    03:46:04 ISDN > # 135 IE: CalledPartyNbr _called_number_
    03:46:04 ISDN > # 136 *newPc BR-U, tei: 0, sapi: 0
    03:46:04 ISDN > # 137 key: 8388619, Stack:2V01b
    03:46:04 ISDN > # 138 EuroISDN
    03:46:04 ISDN > # 139 ---> Layer2 tei: 0 sapi: 0 Setup
    03:46:04 ISDN > # 140 hex:08 01 0B 05 04 03 90 90 A3 1E 02 85 83 6C 0D 00 80 30 35 31 31 39 39 38 32 30 33 35 70 0B 80 30 35
    03:46:04 ISDN > # 141 IE: Bearer
    03:46:04 ISDN > # 142 IE: ProgressInd
    03:46:04 ISDN > # 143 IE: CallingPartyNbr _our_MSN_number_
    03:46:04 ISDN > # 144 IE: CalledPartyNbr _called_number_
    03:46:04 ISDN > # 145 new call state : L3PcSt01U
    03:46:04 ISDN > # 146 p: 0 S: sapi: 0 cr=0 ea=0 tei: 0 ea=1 SABME p =1
    03:46:05 ISDN > # 147 p: 0 S: sapi: 0 cr=0 ea=0 tei: 0 ea=1 SABME p =1
    03:46:06 ISDN > # 148 p: 0 S: sapi: 0 cr=0 ea=0 tei: 0 ea=1 SABME p =1
    03:46:07 ISDN > # 149 p: 0 S: sapi: 0 cr=0 ea=0 tei: 0 ea p =1
    03:46:08 ISDN > # 150 p: 0 TMO : T303 key: 8388619 tei: 0
    03:46:08 ISDN > # 151 ---> Layer2 tei: 0 sapi: 0 Setup
    03:46:08 ISDN > # 152 hex:08 01 0B 05 04 03 90 90 A3 1E 02 85 83 6C 0D 00 80 30 35 31 31 39 39 38 32 30 33 35 70 0B 80 30 35
    03:46:08 ISDN > # 153 IE: Bearer
    03:46:08 ISDN > # 154 IE: ProgressInd
    03:46:08 ISDN > # 155 IE: CallingPartyNbr _our_MSN_number_
    03:46:08 ISDN > # 156 IE: CalledPartyNbr _called_number_
    03:46:08 ISDN > # 157 new call stat
    03:46:08 ISDN > # 158 to CC key: 8388619 L3SetupConfErr
    03:46:08 ISDN > # 159 new call state : L3PcSt00U
    03:46:08 ISDN > # 160 *delPc U, tei: 0 sapi: 0
    03:46:09 ISDN > # 161 p: 0 from CC key: 8388620 L3SetupReq
    03:46:09 ISDN > # 162 Service:Transparent cing: sub: ced: sub:
    03:46:09 ISDN > # 163 cause : Transparent
    03:46:09 ISDN > # 164 hex:04 03 90 90 A3 1E 02 85 83 6C 0D 00 80 30 35 31 31 39 39 38 32 30 33 35 70 0B 80 30 35 31 36 32 34
    03:46:09 ISDN > # 165 IE:
    03:46:09 ISDN > # 166 IE: ProgressInd
    03:46:09 ISDN > # 167 IE: CallingPartyNbr _our_MSN_number_
    03:46:09 ISDN > # 168 IE: CalledPartyNbr _called_number_
    03:46:09 ISDN > # 169 *newPc BR-U, tei: 0, sapi: 0
    03:46:09 ISDN > # 170 key: 8388620, Stack:2V01b
    03:46:09 ISDN > # 171 EuroISDN
    03:46:09 ISDN > # 172 ---> Layer2 tei: 0 sapi: 0 Setup
    03:46:09 ISDN > # 173 hex:08 01 0C 05 04 03 90 90 A3 1E 02 85 83 6C 0D 00 80 30 35 31 31 39 39 38 32 30 33 35 70 0B 80 30
    03:46:09 ISDN > # 174 IE: Bearer
    03:46:09 ISDN > # 175 IE: ProgressInd
    03:46:09 ISDN > # 176 IE: CallingPartyNbr _our_MSN_number_
    03:46:09 ISDN > # 177 IE: CalledPartyNbr _called_number_
    03:46:09 ISDN > # 178 new call state : L3PcSt01U
    03:46:09 ISDN > # 179 p: 0 S: sapi: 0 cr=0 ea=0 tei: 0 ea=1 SABME p =1
    03:46:10 ISDN > # 180 p: 0 S: sapi: 0 cr=0 ea=0 tei: 0 ea=1 SABME p =1
    03:46:11 ISDN > # 181 p: 0 S: sapi: 0 cr=0 ea=0 tei: 0 ea=1 SABME p =1
    03:46:12 ISDN > # 182 p: 0 S: sapi: 0 cr=0 ea=0 tei: 0 ea=1 SABME p =1
    03:46:13 ISDN > # 183 p: 0 TMO : T303 key: 8388620 tei: 0
    03:46:13 ISDN > # 184 ---> Layer2 tei: 0 sapi: 0 Setup
    03:46:13 ISDN > # 185 hex:08 01 0C 05 04 03 90 90 A3 1E 02 85 83 6C 0D 00 80 30 35 31 31 39 39 38 32 30 33 35 70 0B 80 30 35
    03:46:13 ISDN > # 186 IE: Bearer
    03:46:13 ISDN > # 187 IE: ProgressInd
    03:46:13 ISDN > # 188 IE: CallingPartyNbr _our_MSN_number_
    03:46:13 ISDN > # 189 IE: CalledPartyNbr _called_number_
    03:46:13 ISDN > # 190 new call state : L3PcSt01U
    03:46:13 ISDN > # 191 to CC key: 8388620 L3SetupConfErr
    03:46:13 ISDN > # 192 new call state : L3PcSt00U
    03:46:13 ISDN > # 193 *delPc U, tei: 0 sapi: 0
    03:46:14 ISDN > # 194 p: 0 PhDeactInd -> l2
    On 3CX the Patton SmartNode appears as correctly authenticated, even with the (usual) User Agent unmatching:
    :[CM505002]: Gateway:[Patton 4634] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Patton SN4634 3BIS UI MxSF v3.2.8.45 00A0BA0311CF R4.2 2007-09-19 H323 SIP BRI] Transport: [sip:192.168.1.199:5060]
    Cheers
    Luca
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Luca,
    I would like to have Patton's call control debug.
    #debug call-control
  5. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Re: V5 - Cannot initiate outbound calls via Patton 4632
    As far as I see 192.168.1.1 is an IP of gateway, so this 503 error is from gateway, not PBX.
  6. lucasasdelli
    Oct 28, 2007
    7
    Yes, it's the gateway IP, but with 3CX version 3 worked okay. Just after V5 upgrade it stopped outbound calls.
    Cheers
    Luca
  7. lucasasdelli
    Oct 28, 2007
    7
    Uh ... sorry for my mistake.
    Here the log you asked for:
    06:49:11 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Network -> sipgw0
    06:49:11 CC > [EP sipif0-00ed4e30/active] Set call-leg property: E164-Number -> _our_MSN_number_
    06:49:11 CC > [EP sipif0-00ed4e30/active] Set call-leg property: URI -> sip:_our_MSN_number_@192.168.1.1:5060
    06:49:11 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Type-Of-Number -> Unknown
    06:49:11 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Numbering-Plan -> Unknown
    06:49:11 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Presentation-Indicator -> Presentation allowed
    06:49:11 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Name -> 100
    06:49:11 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Screening-Indicator -> User provided, not screened
    06:49:11 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Supports Overlap-Sending -> true
    06:49:11 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Supported Codecs -> Voice: G.711 u-law[20/20], G.711 A-law[20/20]
    06:49:11 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Unique Identifier -> ODM5NGY3MjEwNjZkMTViODUzZDRiMTA4NzQwMmRmYTA.
    06:49:11 CC > [EP sipif0-00ed4e30/active] Set call-leg property: IP-Address -> 192.168.1.199
    06:49:11 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Call-Leg-ID -> 0x00b6aba8
    06:49:11 CC > [EP sipif0-00ed4e30/active] Set call-leg property: State -> CONNECTED
    06:49:11 CC > [Call 00e611b8] Set call property: Context -> 0x00000022
    06:49:11 CC > [Call 00e611b8] Set call property: Information-Transfer-Capability -> 3.1kHz Audio
    06:49:11 CC > [Call 00e611b8] Set call property: Hops -> 0x00000010
    06:49:11 CC > [EP sipif0-00ed4e30/active] Dial to provider router (sipif0-precall-service) using call 00e611b8
    06:49:11 CC > [EP router-00e610b0/incoming] Accept call 00e611b8
    06:49:11 CC > [EP router-00e610b0/incoming] Set call-leg property: E164-Number -> _called_number_
    06:49:11 CC > [EP router-00e610b0/incoming] Set call-leg property: Type-Of-Number -> Unknown
    06:49:11 CC > [EP router-00e610b0/incoming] Set call-leg property: Numbering-Plan -> Unknown
    06:49:11 CC > [EP router-00e610b0/incoming] Set call-leg property: Name ->
    06:49:11 CC > [EP router-00e610b0/incoming] Set call-leg property: URI -> sip:_called_number_@192.168.1.1:5060
    06:49:11 CC > [EP router-00e610b0/incoming] Set call-leg property: Network -> router
    06:49:11 CC > [EP router-00e610b0/incoming] Set call-leg property: Call-Leg-ID -> 0x00b6b500
    06:49:11 CC > [EP router-00e610b0/incoming] Set call-leg property: State -> TRYING
    06:49:11 CC > [EP router-00e610b0] Start route-lookup
    06:49:11 CC > [EP router-00e610b0] Route found; immediately place call
    06:49:11 CC > [EP router-00e610b0] Route to provider 'isdnif0'
    06:49:11 CC > [EP router-00e610b0/outgoing] Set call-leg property: E164-Number -> _our_MSN_number_
    06:49:11 CC > [EP router-00e610b0/outgoing] Set call-leg property: URI -> sip:_our_MSN_number_@192.168.1.1:5060
    06:49:11 CC > [EP router-00e610b0/outgoing] Set call-leg property: Type-Of-Number -> Unknown
    06:49:11 CC > [EP router-00e610b0/outgoing] Set call-leg property: Numbering-Plan -> Unknown
    06:49:11 CC > [EP router-00e610b0/outgoing] Set call-leg property: Presentation-Indicator -> Presentation allowed
    06:49:11 CC > [EP router-00e610b0/outgoing] Set call-leg property: Name -> 100
    06:49:11 CC > [EP router-00e610b0/outgoing] Set call-leg property: Screening-Indicator -> User provided, not screened
    06:49:11 CC > [EP router-00e610b0/outgoing] Set call-leg property: Supports Overlap-Sending -> true
    06:49:11 CC > [EP router-00e610b0/outgoing] Set call-leg property: Supported Codecs -> Voice: G.711 u-law[20/20], G.711 A-law[20/20]
    06:49:11 CC > [EP router-00e610b0/outgoing] Set call-leg property: Unique Identifier -> ODM5NGY3MjEwNjZkMTViODUzZDRiMTA4NzQwMmRmYTA.
    06:49:11 CC > [EP router-00e610b0/outgoing] Set call-leg property: IP-Address -> 192.168.1.199
    06:49:11 CC > [EP router-00e610b0/outgoing] Set call-leg property: Network -> router
    06:49:11 CC > [EP router-00e610b0/outgoing] Set call-leg property: Call-Leg-ID -> 0x00b6cb68
    06:49:11 CC > [EP router-00e610b0/outgoing] Set call-leg property: State -> CONNECTED
    06:49:11 CC > [Call 00b6ca38] Set call property: Context -> 0x00000022
    06:49:11 CC > [Call 00b6ca38] Set call property: Information-Transfer-Capability -> 3.1kHz Audio
    06:49:11 CC > [Call 00b6ca38] Set call property: Hops -> 0x0000000f
    06:49:11 CC > [EP router-00e610b0/outgoing] Dial to provider isdnif0 () using call 00b6ca38
    06:49:11 CC > [EP isdnif0-00b6dc98/active] Accept call 00b6ca38
    06:49:11 CC > [EP isdnif0-00b6dc98/active] Set call-leg property: E164-Number -> _called_number_
    06:49:11 CC > [EP isdnif0-00b6dc98/active] Set call-leg property: Type-Of-Number -> Unknown
    06:49:11 CC > [EP isdnif0-00b6dc98/active] Set call-leg property: Numbering-Plan -> Unknown
    06:49:11 CC > [EP isdnif0-00b6dc98/active] Set call-leg property: Name ->
    06:49:11 CC > [EP isdnif0-00b6dc98/active] Set call-leg property: URI -> sip:_called_number_@192.168.1.1:5060
    06:49:11 CC > [EP isdnif0-00b6dc98/active] Set call-leg property: Network -> isdnif0
    06:49:11 CC > [EP isdnif0-00b6dc98/active] Set call-leg property: Call-Leg-ID -> 0x00b6ff38
    06:49:11 CC > [EP isdnif0-00b6dc98/active] Set call-leg property: State -> TRYING
    06:49:11 CC > [EP isdnif0-00b6dc98/active] Set call-leg property: Endpoint-Is-Isdn -> true
    06:49:11 CC > [Call 00e611b8] Set call property: Hops -> 0x0000000f
    06:49:11 CC > [EP router-00e610b0/incoming] Set call-leg property: Endpoint-Is-Isdn -> true
    06:49:15 CC > [EP isdnif0-00b6dc98/active] Set call-leg property: Cause -> Network out of order
    06:49:15 CC > [EP isdnif0-00b6dc98/active] Drop call 00b6ca38
    06:49:15 CC > [EP isdnif0-00b6dc98/active] Set call-leg property: State -> RELEASED
    06:49:15 CC > [EP router-00e610b0/incoming] Set call-leg property: Cause -> Network out of order
    06:49:15 CC > [EP router-00e610b0/incoming] Set call-leg property: State -> RELEASED
    06:49:15 CC > [EP router-00e610b0/outgoing] Drop call 00b6ca38
    06:49:15 CC > [EP router-00e610b0/outgoing] Set call-leg property: Cause -> Normal call clearing
    06:49:15 CC > [EP router-00e610b0/outgoing] Set call-leg property: State -> RELEASED
    06:49:15 CC > [EP sipif0-00ed4e30/active] Drop call 00e611b8
    06:49:15 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Cause -> Normal call clearing
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: State -> RELEASED
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Network -> sipgw0
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: E164-Number -> _our_MSN_number_
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: URI -> sip:_our_MSN_number_@192.168.1.1:5060
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Type-Of-Number -> Unknown
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Numbering-Plan -> Unknown
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Presentation-Indicator -> Presentation allowed
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Name -> 100
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Screening-Indicator -> User provided, not screened
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Supports Overlap-Sending -> true
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Supported Codecs -> Voice: G.711 u-law[20/20], G.711 A-law[20/20]
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Unique Identifier -> Yjg1MWVmMzgxZGRmYWM4NTViNDdhZWY1OGYyMzQ5MTc.
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: IP-Address -> 192.168.1.199
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Call-Leg-ID -> 0x00ecf910
    06:49:16 CC > [EP sipif0-00ed4e30/active] Set call-leg property: State -> CONNECTED
    06:49:16 CC > [Call 00e600f8] Set call property: Context -> 0x00000022
    06:49:16 CC > [Call 00e600f8] Set call property: Information-Transfer-Capability -> 3.1kHz Audio
    06:49:16 CC > [Call 00e600f8] Set call property: Hops -> 0x00000010
    06:49:16 CC > [EP sipif0-00ed4e30/active] Dial to provider router (sipif0-precall-service) using call 00e600f8
    06:49:16 CC > [EP router-00b6be58/incoming] Accept call 00e600f8
    06:49:16 CC > [EP router-00b6be58/incoming] Set call-leg property: E164-Number -> _called_number_
    06:49:16 CC > [EP router-00b6be58/incoming] Set call-leg property: Type-Of-Number -> Unknown
    06:49:16 CC > [EP router-00b6be58/incoming] Set call-leg property: Numbering-Plan -> Unknown
    06:49:16 CC > [EP router-00b6be58/incoming] Set call-leg property: Name ->
    06:49:16 CC > [EP router-00b6be58/incoming] Set call-leg property: URI -> sip:_called_number_@192.168.1.1:5060
    06:49:16 CC > [EP router-00b6be58/incoming] Set call-leg property: Network -> router
    06:49:16 CC > [EP router-00b6be58/incoming] Set call-leg property: Call-Leg-ID -> 0x00b6ae10
    06:49:16 CC > [EP router-00b6be58/incoming] Set call-leg property: State -> TRYING
    06:49:16 CC > [EP router-00b6be58] Start route-lookup
    06:49:16 CC > [EP router-00b6be58] Route found; immediately place call
    06:49:16 CC > [EP router-00b6be58] Route to provider 'isdnif0'
    06:49:16 CC > [EP router-00b6be58/outgoing] Set call-leg property: E164-Number -> _our_MSN_number_
    06:49:16 CC > [EP router-00b6be58/outgoing] Set call-leg property: URI -> sip:_our_MSN_number_@192.168.1.1:5060
    06:49:16 CC > [EP router-00b6be58/outgoing] Set call-leg property: Type-Of-Number -> Unknown
    06:49:16 CC > [EP router-00b6be58/outgoing] Set call-leg property: Numbering-Plan -> Unknown
    06:49:16 CC > [EP router-00b6be58/outgoing] Set call-leg property: Presentation-Indicator -> Presentation allowed
    06:49:16 CC > [EP router-00b6be58/outgoing] Set call-leg property: Name -> 100
    06:49:16 CC > [EP router-00b6be58/outgoing] Set call-leg property: Screening-Indicator -> User provided, not screened
    06:49:16 CC > [EP router-00b6be58/outgoing] Set call-leg property: Supports Overlap-Sending -> true
    06:49:16 CC > [EP router-00b6be58/outgoing] Set call-leg property: Supported Codecs -> Voice: G.711 u-law[20/20], G.711 A-law[20/20]
    06:49:16 CC > [EP router-00b6be58/outgoing] Set call-leg property: Unique Identifier -> Yjg1MWVmMzgxZGRmYWM4NTViNDdhZWY1OGYyMzQ5MTc.
    06:49:16 CC > [EP router-00b6be58/outgoing] Set call-leg property: IP-Address -> 192.168.1.199
    06:49:16 CC > [EP router-00b6be58/outgoing] Set call-leg property: Network -> router
    06:49:16 CC > [EP router-00b6be58/outgoing] Set call-leg property: Call-Leg-ID -> 0x00b6fb30
    06:49:16 CC > [EP router-00b6be58/outgoing] Set call-leg property: State -> CONNECTED
    06:49:16 CC > [Call 00b6f8f0] Set call property: Context -> 0x00000022
    06:49:16 CC > [Call 00b6f8f0] Set call property: Information-Transfer-Capability -> 3.1kHz Audio
    06:49:16 CC > [Call 00b6f8f0] Set call property: Hops -> 0x0000000f
    06:49:16 CC > [EP router-00b6be58/outgoing] Dial to provider isdnif0 () using call 00b6f8f0
    06:49:16 CC > [EP isdnif0-00b6f528/active] Accept call 00b6f8f0
    06:49:16 CC > [EP isdnif0-00b6f528/active] Set call-leg property: E164-Number -> _called_number_
    06:49:16 CC > [EP isdnif0-00b6f528/active] Set call-leg property: Type-Of-Number -> Unknown
    06:49:16 CC > [EP isdnif0-00b6f528/active] Set call-leg property: Numbering-Plan -> Unknown
    06:49:16 CC > [EP isdnif0-00b6f528/active] Set call-leg property: Name ->
    06:49:16 CC > [EP isdnif0-00b6f528/active] Set call-leg property: URI -> sip:_called_number_@192.168.1.1:5060
    06:49:16 CC > [EP isdnif0-00b6f528/active] Set call-leg property: Network -> isdnif0
    06:49:16 CC > [EP isdnif0-00b6f528/active] Set call-leg property: Call-Leg-ID -> 0x00b72820
    06:49:16 CC > [EP isdnif0-00b6f528/active] Set call-leg property: State -> TRYING
    06:49:16 CC > [EP isdnif0-00b6f528/active] Set call-leg property: Endpoint-Is-Isdn -> true
    06:49:16 CC > [Call 00e600f8] Set call property: Hops -> 0x0000000f
    06:49:16 CC > [EP router-00b6be58/incoming] Set call-leg property: Endpoint-Is-Isdn -> true
    06:49:20 CC > [EP isdnif0-00b6f528/active] Set call-leg property: Cause -> Network out of order
    06:49:20 CC > [EP isdnif0-00b6f528/active] Drop call 00b6f8f0
    06:49:20 CC > [EP isdnif0-00b6f528/active] Set call-leg property: State -> RELEASED
    06:49:20 CC > [EP router-00b6be58/incoming] Set call-leg property: Cause -> Network out of order
    06:49:20 CC > [EP router-00b6be58/incoming] Set call-leg property: State -> RELEASED
    06:49:20 CC > [EP router-00b6be58/outgoing] Drop call 00b6f8f0
    06:49:20 CC > [EP router-00b6be58/outgoing] Set call-leg property: Cause -> Normal call clearing
    06:49:20 CC > [EP router-00b6be58/outgoing] Set call-leg property: State -> RELEASED
    06:49:20 CC > [EP sipif0-00ed4e30/active] Drop call 00e600f8
    06:49:20 CC > [EP sipif0-00ed4e30/active] Set call-leg property: Cause -> Normal call clearing
    06:49:20 CC > [EP sipif0-00ed4e30/active] Set call-leg property: State -> RELEASED
    There are some "Network our of order" messages; BTW the incoming calls are correctly answered to, as well as direct ISDN lines connected to a standard ISDN phone (both incoming and outgoing calls).
    Cheers
    Luca
