V5 STUN server no IP allowed
Discussion in '3CX Phone System - General' started by andy, Dec 8, 2007.
  1. andy
    Oct 22, 2007
    23
    in V3 i had an IP configured as the STUN server. Now in V5 it only allows DNS-domain names. no IP
  2. jparisi
    Oct 1, 2007
    92
    Until you get an answer, you can work around it by putting a host entry in your hosts file that points to the IP you need.
    For example:
    stun.mystun.com x.x.x.x
    Where the x's are the IPs
  3. Mori
    Mori New Member
    Mar 23, 2007
    223
    The latest upgrade 5.0.3648 allows IP in stun.
