V5 Weird transfer problem cant hear
Discussion in '3CX Phone System - General' started by AldoLinares, Jan 9, 2008.
  1. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    Setup:
    4 FXS - Grandstream GXW4004
    4 FXO - Grandstream GXW4104
    1 IP Phone - GXP2000
    When i get a call from PSTN and answer on the phone on the GXP2000 and then doing a transfer (not blind, blind works) to a FXS Phone i dont hear the PSTN on the FXS i can only hear from the PSTN
    Any help?
  2. AldoLinares
    Nov 12, 2007
    135
    Whats the diference between doing a blind transfer and an assistant transfer, why the blind transfer works fine.
  3. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Are you using the same codecs? Dont know if actually this has to do with it, but its a chance... i've not installed V5 yet due its bugs.... i will try it again thoug this week, give once again a chance, to see if i can make it work like in V3.
    Cheers
  4. AldoLinares
    Nov 12, 2007
    135
    Yea they are the same codecs, and everything works fine, just a transfer between IP Phone and FXS phone with atendant transfer fails. blind works from a call from PSTN.
    The bad part of this is that its not a test setup but a setup for a production with 15 phones 4 FXS only.
