v6.0.18815.0 for Windows - Audio device detect ** Feat. Requ
Discussion in 'Windows' started by jr3151006, Jun 2, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    Hi dev Team,
    I would like to sugest you to implement a 'previous check' when the software is started regarding the audio device. I will explain my case.
    I have MS LifeChat Zx-6000 (http://www.microsoft.com/nz/hardware/digitalcommunication/productdetails.aspx?pid=004) setted as default device, works fine with my W7 and automatically detected by MSN/Skype when connected.
    I was not able to use it with '3CX softphone' until go to the options and change the audio device; after that I´m able to use it. Everything works fine so far...
    In the next day I wasn´t using that device, I opened the softphone without errors but when I tried to dial it shows as 'ended', using the debug window I realize that the problem was related with the 'missing device'.
    Can you check/review that case?
    Renato P
