v7.1 Backup Restore on v8.0
Discussion in '3CX Phone System - General' started by jas07, Dec 4, 2009.
  1. jas07
    Mar 23, 2009
    28
    Hi Guys,
    Will a backup ive made in 3CX v7.1 restore fine on v8.0?
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Yes, that is the recommended method for upgrading.
  3. jas07
    Mar 23, 2009
    28
    Thanks Kerry
