V7 Server Activity log / worse entry´s
Discussion in '3CX Phone System - General' started by silentfun, Nov 20, 2008.
  1. silentfun
    silentfun Member
    Dec 11, 2006
    364
    Anyone know what this means? i don´t understant what this mean´s ? Dose the dialcodes try to login as extensions?
    it stopped this massive logspam when i stoped the parking orbit service.
    21:06:10.296 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=e86dac6c8866e61a cseq=REGISTER contact=*1@127.0.0.1:40000 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    21:06:10.296 [CM502001]: Source info: From: "Unpark line"<sip:*1@127.0.0.1:5060>;tag=ca343742; To: "Unpark line"<sip:*1@127.0.0.1:5060>
    21:06:10.296 [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 127.0.0.1:5060 tid=e86dac6c8866e61a cseq=REGISTER contact=*1@127.0.0.1:40000 / 2 from(wire)
    21:06:10.187 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=464913516f239e46 cseq=REGISTER contact=*0@127.0.0.1:40000 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    21:06:10.187 [CM502001]: Source info: From: "Park line"<sip:*0@127.0.0.1:5060>;tag=9d03eb72; To: "Park line"<sip:*0@127.0.0.1:5060>
    21:06:10.187 [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 127.0.0.1:5060 tid=464913516f239e46 cseq=REGISTER contact=*0@127.0.0.1:40000 / 2 from(wire)
    21:06:09.859 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=5642934c8f38761f cseq=REGISTER contact=*1@127.0.0.1:40000 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    21:06:09.859 [CM502001]: Source info: From: "Unpark line"<sip:*1@127.0.0.1:5060>;tag=dc47a014; To: "Unpark line"<sip:*1@127.0.0.1:5060>
    21:06:09.859 [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 127.0.0.1:5060 tid=5642934c8f38761f cseq=REGISTER contact=*1@127.0.0.1:40000 / 2 from(wire)
    21:06:09.750 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=77514059e1512202 cseq=REGISTER contact=*0@127.0.0.1:40000 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    21:06:09.750 [CM502001]: Source info: From: "Park line"<sip:*0@127.0.0.1:5060>;tag=48792b1c; To: "Park line"<sip:*0@127.0.0.1:5060>
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    It means that your PBX is not properly configured.
    Do you have any additional information?
  3. silentfun
    silentfun Member
    Dec 11, 2006
    364
    this was a fresh install just 1 ext (green) 1 Voipprovider (green).
    the wizzard questions was answered.
    nothing else configured.
    Andy
  4. SY
    3CX Support
    Jan 26, 2007
    1,825
    Andy,
    Thanks a lot for the information
  5. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Thanks for your reply.
    Assuming you are using the latest build , can you please go to the Settings > Dial Codes section, Click APPLY and OK and see if the issue persists.
  6. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    Can you send us
    1) a backup of your PBX settings and
    2) The wizard logs from here
    C:\Program Files (x86)\3CX PhoneSystem\Bin
    3cxwizard.txt
    Send them to nb@3cx.com directly (if the backup file is too big you can put somewhere publicly available and I will download it no problem.
  7. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    OK Guys - there is an easier workaround than taking a backup and restoring it!!
    Do the following
    Go to Advanced in the management console
    Click on the Dial Codes Tab
    Change the Parking code to something else example *7 (something that does not exist as a dial code.)
    Change the Pickup a Parked Call to something else example *8 (also a unique dial code)
    Click Apply and OK.
    The Spamming will stop and the new dial codes will register using *7 and *8.
    After this go back to the dial codes page and revert *7 and *8 to what they originally were i.e.*0 and *1
    Again the previous dial codes (*7 and *8) will unregister and *0 and *1 will register with success.
    Let us know on the progress you make on this. Ideally at this point it would be much appreciated if you send me the 3cxwizard.txt file just the same. The backups are not required any more.
