v8
SWSDEV
Forum User
Does the VAD work with version 8 yet?
Yes, actually the latest version of the VAD only works with V8.
OK, I guess I missed it when it changed over, I still have the beta.
Do the server components work on 64bit?
Where can I download the new version? I only see download links for the beta version still
Yes, it works in 32 or 64 bits systems. You don't need to install server components any more, they are automatically installed by 3CX.
You can download the latest version from http://www.3cx.com/downloads/3CXVAD2.msi
The manual is available at http://www.3cx.com/manual/3CXVADManual2.pdf
Regards,
Do I need to uninstall the old beta version first?
Yes, uninstall first.
Get 3CX - Absolutely Free!
3CX
