v9 extension not forwarding calls to external number
Discussion in '3CX Phone System - General' started by DavidK, Aug 5, 2010.
  1. DavidK
    Apr 5, 2009
    12
    I just installed v9 from v8. I have 2 extensions setup to go out to external cell phones.
    1 is part of a ring group, set to ring all.
    They worked perfectly under v8, but under v9 call are not being sent to the phones.
    I changed it from send to an external number to call my mobile number, but nothing.
    I set the ring group that is no answer send to an external number, and have it working that way for now.
    Anyone have any ideas?
    Thanks,
    David
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,473
    94
    Hi i've tried this out and it seems to be working perfectly in my scenario.
    Can you check for the option in: Settings > General Settings > Global Options > Forward Ring Group / Queues to external numbers and make sure it's ticked?
  3. DavidK
    Apr 5, 2009
    12
    That box is checked.
    I had uped from v8, and had exported/imported all the settings. Everything worked well in v8.
    The extension shows as not registered, which it should as it is being forwarded to a cell phone.
    I've put forward to external number is all of the option boxes for that extension, but from the ring group will not send calls to it.
    If you dial that extension directly it goes thru.
    David
  4. DavidK
    Apr 5, 2009
    12
    Well I created an AA with option 2 going to the extension I would like it to ring to.
    But for some reason it seems like the ring groups and call ques are not seeing the extension.
    It has a red bullet next to it (as it should, its a cell phone, not a physical extension), but I have it set to Available and Logged In.
    Again this worked fine in v8.
    The above is just a quick fix I've found.
    System is:
    Intel Atom 330
    2GB RAM
    500GB SATA2 HD
    M$ Win XP Pro SP3 running the built in 3CX Abyss
    3CX v9.0.13545.594 (Just tried updating to SP1 - No change)
    Thanks,
    David
  5. xor@redlink.de
    Jan 23, 2009
    18
    I just experienced the same problem. In v8 it worked when the extension was "not registered" but "available" and "logged in" and the external number was configured under "if phone is busy or unregistered".
    This behaviour has changed in v9, it doesn't work any more. Extensions that are "not registered" but set to "available" are ignored in call queues.
    To make it work again, the forwarding has to be configured under "away". The extensions status then has to be set to "away" instead of "available" of course.
    Tammo
  6. DavidK
    Apr 5, 2009
    12
    Tammo,
    Thank you, that did the trick.
    David
