(v9) forward to external number if extension not registered
Discussion in '3CX Phone System - General' started by psiho, Feb 28, 2011.
  1. psiho
    Apr 7, 2010
    I use only 2 extensions at home. One is fixed phone (ext 100) and another one is my personal which I use to connect from my mobile phone client (ext 101). But I'm not allways connected with my mobile client so in situation like that I would like to forward all incomming calls to some external number.
    When I edit properties of ext 101 and visit "forwarding rules" tab I get options for Available, Away, out of office, etc... but I don't see "not registered". I belive there was "not registered" option in v8?
    Now I'm lost, how to to forward calls IF extension is not registered.
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Re: (v9) forward to external number if extension not registe
    It is under available
    Available has 2 parts - one for registered, rings but no answer and the lower part for busy or not registered.
  3. psiho
    Apr 7, 2010
    Uh, thx, I see it now... but there's quite a big difference between busy and unregistered. I would prefer to simply disconnect or play busy signal if busy, not transfer anywhere. :( But if that's the only option I can live with it. It's not too busy line.
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    if you believe this should be a separate feature please go ahead and post it on ideas.3cx.com.
