V9 Help/Manual displays V8 manual**FIX CONFIRMED NXT UPDATE
Discussion in '3CX Phone System - General' started by carolinainnovative, Jul 21, 2010.
  1. carolinainnovative
    May 4, 2009
    369
    6
    Re: V9 Help/Manual displays V8 manual
    This is still happening in RC2. I can't speak for "Fresh installs" - but on upgrades, this is the case.
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Yes, we know about this we will add the v9 manual when all manual for all languages are ready.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,153
    174
    Will be fixed in next update.
