V9 on Win2k8R2 in a VM
Discussion in '3CX Phone System - General' started by coreybrett, Jul 29, 2010.
  1. coreybrett
    Apr 12, 2010
    72
    I'm getting ready to migrate my phone system from an existing 3CXv8 (running on XP with a real computer) to a new v9 setup with Win2k8R2 in a Hyper-V VM. I'm using http://www.3cx.com/blog/docs/hyper-v-instance/ as a guide and have a few questions.
    The article says
    what is this for?
    The article says
    what us this for?
    I don't really have an issue with doing these things, I'm just curious what they are for.
    I will not be using the Sykpe feature.
    I plan on using Abyss.
    I have about 20 extensions and use a VOIP provider.
    Any other thoughts or suggestions would be appreciated.
  2. carolinainnovative
    May 4, 2009
    369
    6
    As far as I understand, Desktop Experience installs components that then install some codecs which are required. See here for what all is included in Desktop Experience -
    http://technet.microsoft.com/en-us/library/cc772567.aspx
    Windows Media Player is one of those things...
  3. vpaulo
    Jun 24, 2009
    23
    I use win2k8r2 over year. WE dont have any problem whith v8. and v9. All work fine without any additional components.
  4. bruno479
    Jul 9, 2010
    7
    As i understand that is used for the following:
    voice mail and music on-hold
